Previous in Forum: Gulf Oil Spill and Toxic Chemicals   Next in Forum: Can I Seal Two Polymers With Different Coe's?
when to use argon gas or liquid nitrogen during metal processing?
06/26/2010 5:33 AM
to prevent oxidation we use argon gas or liquid nitrogen during processing or during experimentation of materials. what is the main difference between them? I know argon is used at higher temperature. I am looking for precise difference between the two. thanks
Good Answers: 61
Re: when to use argon gas or liquid nitrogen during metal processing?
06/26/2010 11:40 AM
Argon is one of the "noble gasses" - Group 8 in the periodic table - helium, neon, argon, krypton, xenon & radon. These are, to all intents and purpose completey inert, not reacting with anything (in fact, they can be made to form a few compounds under very aggressive conditions, typically with fluorine).
Nitrogen is regarded as an "inert gas" as it is also very unreactive. However, it does react at high tremperatures with many metals (typically the transition metals used in steels, Ti,V,Mn,Fe,Cr,Fe,Co,Ni) to form nitrides. Most of these nitrides are not true compounds, but "interstital compounds" of no fixed composition, in which nitrogen atoms are trapped in the gaps between the metal atoms (the interstices). The small nitrogen atoms prevent the crystalline layers of metal from sliding over each other, thus producing a very tough, hard surface. You have probably heard of nitrided steel and case hardening - used in situations where wear (oops, sorry) is a big issue - gears, steering racks, camshafts, tool dies, etc.
I hope this is of some help.
Good Answers: 243
06/26/2010 9:09 PM
GA Milo.
Good Answers: 61
06/26/2010 11:06 PM
My typing error - "interstitial" not "interstital." Apologies.
06/27/2010 10:45 AM
No apology necessary. Those of us who understand the word got it. To the rest it wouldn't matter anyway.
Very well put, by the way.
06/28/2010 3:13 AM
Argon gas is a single atom molecue. Argon has very little in the way of chemistry and will not react with metals.
Nitrogen is a two-atom molecule. Nitrogen does have some chemistry. At high temperatures nitrogen, in the presence of oxygen, reacts endothermically to form nitrogen oixides, which may or may not be wanted in contact with metals. Nitrogen oxides dissolve in water to form strong acids, which react with many metals. Nitrogen will also react endothermically with some metals to form nitrides, which are very hard, and can be used to impart special mechanical properties to those metals for the purposes of making machine tools, among other things.
Wikipedia has comprehensive articles on both these elements, and in the chemistry of nitrogen.
energyconversion (2); lyn (1); Milo (1); PWSlack (1)
You might be interested in: Nitrogen Lasers, Materials Processing Services
