Previous in Forum: API 579   Next in Forum: mechanical engineering
Relationship of Coil ADP & Chilled Water In/Out Temp.
06/26/2010 12:37 PM
How the coil ADP is related with chilled water in & out temperature?
How do we select the equipment with chilled water in /out based on the selected /Indicated ADP based on our calculation.
Please clarify...
Chellapillai Srinivasan
Pathfinder Tags: Coil ADP
Good Answers: 101
Re: Relationship of Coil ADP & Chilled Water In/Out Temp.
06/27/2010 12:08 AM
You got it backwards. The cooling system is selected based upon th following criteria: maximum allowable temperature, required temperature, power consumption of equipment to be cooled, energy efficiency of said equipment and cooling medium to be used e.g. water or air. The equipment is sized and selected from there.
