Previous in Forum: Relationship of Coil ADP & Chilled Water In/Out Temp.   Next in Forum: Pump Motor RPM
12 comments
mechanical engineering
06/27/2010 12:59 AM
what is the calculating method to arrive at the tonnage required to punch a hole of size 20 mm dia in a hydraulic press? will it be different for a mechanical press? similarly hpw to calculate the capacity of a press for regular punching jobs?
Good Answers: 97
Re: mechanical engineering
06/27/2010 1:28 AM
What material?
CRTL-Z
06/27/2010 2:16 AM
steel is the material used
Reply Off Topic (Score 4)
Good Answers: 97
06/27/2010 1:29 AM
Next question:
Material thickness?
CRTL-Z
06/27/2010 2:17 AM
thickness of the material is 6 mm.
06/27/2010 1:42 AM
Shear strength of material ÷ (perimeter of hole × thickness of material), using consistent units.
India - Member - New Member
Good Answers: 164
06/27/2010 7:26 AM
Pardon me .. i was under the impression that it is
Force = Shear Strength X perimeter X thickness ?
06/27/2010 2:25 PM
Thanks for correcting me. I don't know how I made that slip.
06/27/2010 2:43 PM
Look at the time you posted it, maybe that had something to do with it.
06/28/2010 8:59 AM
It's Vader.
He got me with a Jedi Mind trick the other day (he tricked me into saying gasoline sells for $1.55/gallon)... he seems to be on a spree.
I think you make his recent victim count ten, perhaps eleven.
06/27/2010 2:23 AM
For a hydraulic press, the force exerted is internal cross-sectional area of cylinder(s) × pressure of hydraulic fluid. For a mechanical press, you have to analyze levers and forces, and inertial effects of parts tha move and stop quickly. That depends on lots of detail.
Good Answers: 164
06/27/2010 7:24 AM
Your query seems to have been adequately answered, still ... here is a link to help (as long as you can convert mm to inches)
http://www.anvilfire.com/21centbs/math/punching_steel.htm
06/27/2010 9:03 AM
Don't forget the tolerances for the clearance between the punch and die
Doorman (1); kvsridhar (2); muruga prasad (2); phoenix911 (2); Tornado (3); Unredundant (2)
