Previous in Forum: Power Loss, Step Up Ratios   Next in Forum: Size of the Shaft for Torque
Heat Transfer from our Bodies
02/23/2007 11:45 AM
When you are in fear the body gets cold how does the heat dissipate from the body without any change in the temprature of the surrounding.How does the rapid rate of cooling of the body takes place.
Re: Heat Transfer from our Bodies
02/23/2007 6:05 PM
It happens via phase change. Water (or sweat) must absorb energy from its surroundings to change to a vapor. This energy is called "latent heat". So, water that is on your skin and in your lungs evaporates, taking some thermal energy with it while the temperature does not actually change. Thus, if the air is dry enough, vapor containing thermal energy is taken away from your body and dissipated to the air. This feels oh-so good in the summer time.
note: A person WILL heat up the air around them, just ask an HVAC guy about that.
OK, that one was free but the next one will cost ya' 2 cents
02/25/2007 8:51 AM
And dont forget that in fear, your body contracts the veins reducing the amount of blood circulating in non essencial areas. This also contributes to the cold skin feeling, as well as the palid look.
Humm... suspicious you are...
Register to Reply 2 comments
