Previous in Forum: Heat Transfer from our Bodies   Next in Forum: Hydrotesting of Process Piping
Size of the Shaft for Torque
02/23/2007 12:10 PM
How the size of the shaft can be calculated if the torque is given as 25555N stress is 45mpa/mm^2.and .5rps
Re: Size of the Shaft for Torque
02/24/2007 6:31 AM
Torque(T, in N.m)/Moment of area (J, in m4)= Shear stress (in MPa) /Outer fibre radius(R, in m).
Power = Torque x angular velocity
What application are you going to use this shaft? Which stress is 45 MPa? Is it a hollow or solid shaft?
A person who has never made a mistake, has never tried anything new.
02/24/2007 10:09 AM
This shaft will be used to rotate a heavy object which will be pivoted at the shaft center
and having a weight of 2500n its solid shaft.Its rotated at 1rps.
02/26/2007 1:42 AM
Anyway I believe you do know the basics of strength of materials or machine designs or any theory of failures. If not, I think much more comprehensive textbooks, journals, manufacture- and other publications are available and should be consulted.
Whatever theory you apply, it is clear that the maximum resultant bending moment and the resultant maximum torque must be first determined.
The bending moment at any section on a shaft is the algebraic sum of moments of the forces to the one side of the section. So you need to know the length of your shaft, its supports and the location of a heavy object on your shaft.
Shafts may be subjected to various combinations of axial, tensile and compressive loads as well as torsion and bending and these may be appied under gradual, sudden, shock and cyclic conditions. So you need to know the type of load on your shaft in order to consider i.e shock and fatigue load factors, etc.
The limiting ruling section(LRS), refers to the maximum value of the external diameter of a shaft for which the listed stress is applicable. As the cross sectional dimensions of steel increases, the strength decreases, so it is therefore required to reflect this tendency. Consult BS 970: Part 1: Check mechanical properties of a selection of steels
Legal aspects are covered under OSH Act. As shaft is such a common part of driven machinery, all regulations must be complied with.
For example if you consider only twisting and bending:
The polar second moment area of the shaft cross section (J) in m4
J = (π/32) x d4
Where: d = diameter of a solid shaft in metres.
If for example you are using Guest's or Tresca's maximum shear stress theory of failure:
If the maximum shear stress generated in the material of a shaft by action of combined bending and twisting, is equal to a shear stress generated by a twisting moment(torque) acting singly, the latter twisting moment is referred to as equivalent torque (Te).
T/J = τ/R
Therefore: (1) Te = (π τmax d3)/16
(2) Te = (M2 + T2)1/2 , Where: M= maximum bending moment and T= maximim torque
Incase combined shock and fatigue factors for bending (Kb) and torsion (Kt) are considered,then Te = [ (KbM)2 + (KtT)2]1/2 .....................................(3)
By equating (1) to (2) or(3) , suitable shaft diameter for solid shafts may be calculated.
This is just an example, you may calculate according to any theory of failures popular in morden technology.I hope these basic principles will help.
Good Answers: 137
02/26/2007 6:21 AM
It's easy! I assume you mean 25555 N.m torque (judging by the low speed 30 rpm this seems more likely than N.mm). Stress is MPa, not MPa/mm2. (MPa = MN/m2 = N/mm2)
Torsional modulus Z = torque/stress 567890 mm3. Assuming it's a solid shaft Z = pi.r3 where r = shaft radius. D = 2.r comes to 113.1 mm. If it's a hollow shaft it's a bit more complicated, torque/stress = I/ro = pi.(ro4 - ri4)/ro, using an obvious notation where I = 2nd moment of area. You then need to choose suitable ro and ri.
Shaft speed doesn't come into diameter calc, but at speed given power (= torque x speed in radians/sec) = 80.3 kW.
Good Answers: 137
02/27/2007 1:03 PM
I made a mistake in earlier posting, specially embarrassing after saying it's easy! But at least it's better than the error being pointed out by somebody else.
For a solid shaft, torsional Z = pi/2.r3 not pi.r3 and D comes to 142.5 mm.
For a hollow shaft torque/stress = I/ro = pi/2.(ro4 - ri4)/ro. E.g. if Do = 160 mm, Di = 118 mm.
Cheers.... Codey
Anonymous Poster (1); Codemaster (2); Mazwi Buthelezi (2)
