i have a gas suction system from electrolysis pot cell through a ramifying pipeline to a treatment station. a centrifugal fan is situated downstream.
when pots are stopped, parts of the pipeline are isolated fron the network and the total quantity of gases getting into the fan reduces. there is also a decrease in the flow rate and system load. all along the fan turns at the same speed
i wish to have the same flow rate at the chimney( situated after the fan) independent of the number of pots functionning. i have chosed to use an inlet vane damper.
i have doubts if this will be able to keep my flow rate constant or it will just match the static pressure of the fan to the corresponding system load.
