Previous in Forum: Advises on how to Fit Markon and Series 4 AVR   Next in Forum: Core Loss, Copper Loss, Inductive Loss?
broken neutral conductor and the protective conductor
06/28/2010 2:58 PM
Can one use the voltage between the broken neutral conductor and the protective conductor
Re: broken neutral conductor and the protective conductor
06/28/2010 3:38 PM
I presume one could use this for a broken neutral detection circuit. But short of this, I do not see any way one could reasonably and safely utilize this.
Good Answers: 145
06/28/2010 3:38 PM
Always best to be both legal and safe. Therefore, the best answer is "no".
06/28/2010 3:40 PM
Do you mean using the possible potential difference between the Neutral and Earth (or Ground) due (generally) to inductive coupling, which in many (if not most) electrical systems is supposed to be bonded together and at the same potential to prevent an electric shock?
In what way and why on earth would you want to (this is totally impractical and extremely unsafe and in many circumstances can can lead to electrocution)? You cannot power an electrical appliance for free of this if that is what you are thinking!
Can you please provide more information, including your country (electrical systems vary from country to country).
Good Answers: 101
06/28/2010 7:22 PM
Alright, my latest victim.....
India - Member - New Member
Good Answers: 164
06/28/2010 10:57 PM
Vader, you may not be that far off. Look at what some students of my alma mater have done here
If this is done in this college, i do believe MIT, CalTech, Rennselaer etc ...must be doing far more ???
Good Answers: 101
06/29/2010 8:08 AM
06/29/2010 2:59 AM
Practically no. This voltage varies with imbalance currents elasewhere on the distribution network.
According to national standards, no. Such a concept is certainly outside BS7671.
Morally, no. In the event of a disconnection in the neutral upstream, the neutral-to-earth voltage rises to the full phase voltage. Therefore there is a risk of equipment damage, fire and electrocution, and therefore a risk of prosecution. No-one wants that, surely?
If in doubt, consult a qualified electrician.
BruceFlorida (1); DVader1000 (2); jack of all trades (1); kvsridhar (1); PWSlack (1); redfred (1)
