Previous in Forum: Rock Tumblers   Next in Forum: Gun possession and the Supreme Court. Where do we go from here?
9 comments
Function of Flux
06/28/2010 11:43 PM
During SMAW the solidified layer of flux deposits over the weld bead, because flux being lighter in density compared to weld bead.But during over head welding why not this flux go up.
Re: Function of Flux
06/28/2010 11:51 PM
Repeated Post Warning
06/28/2010 11:59 PM
This is the second time for this question.
When you weld normally, you point the welder down and the metal pushes the flux, "up".
When you weld overhead, you point the welder up. This reverses the polarity of the ground and the metal goes up and pushes the flux, "down".
06/29/2010 10:57 AM
"When you weld overhead, you point the welder up. This reverses the polarity of the ground and the metal goes up and pushes the flux, "down"."
Intriguing. Does this phenomenon also manifest in the southern hemisphere?
06/29/2010 11:00 AM
Of course. But, as you might suspect, the effect is reversed.
It's nice to have your own straight man.
06/29/2010 11:16 AM
Perhaps you have read my bio:
Available from LynDoor® Industries.
Reply Off Topic (Score 3)
07/01/2010 9:27 AM
I am confused, how automatically the polarity changes in overhead welding. please comment
Good Answers: 58
06/29/2010 11:38 PM
I think the key word is this situation is 'affinity'. Two beads of water will join into one. 'Surface tension' will keep the bead together. It's what fluids do. During welding, you are dealing with fluid metal, and fluid flux. The metal has affinity for metal, so down or up, the metal combines. The flux has some affinity for the metal, being a fluid, but surface tension of the metal excludes the flux.
The flux is mostly to keep air from affecting the molten metal while it solidifies.
mike k
06/30/2010 7:36 PM
Oh Man,
You take all the fun out of it.
I did get a chuckle out of, "It's what fluids do".
GA.
12/07/2010 5:58 AM
apsulutelyy right sir
4 chem afinity
in f/n 2 recover d metal n 2 mk d slag
flux like lime, lime stone ... added..
Anonymous Poster (2); Doorman (2); lyn (3); mike k (1); Tornado (1)
