Previous in Forum: What is Nano?   Next in Forum: Water Pump
11 comments
Composite Gas Cylinders
06/29/2010 3:42 PM
As we plan to start the project in Egypt is there any answer for the durability of the cylinders in rough use as they are doing to the steel.If one drops from the top of a truck what will be the result?Also is any one interested to work together in Egypt?
Re: composite gass cylinders
06/29/2010 4:05 PM
"...interested to work together in Egypt?"
No, thanks anyway. Not if you are already planning to drop cylinders of compressed anything from the top of a truck!
You might try to keep that detail quiet... might get you better employee candidates.
06/29/2010 4:16 PM
maybe you are not familiar with egyptian workers.Did you ever see the way they handle the laborers the cylinders?
Good Answers: 101
06/29/2010 7:38 PM
If the valve gets damaged you may get gas leakage. Why not employ supervisors to ensure they do the job properly and impose heavy penalties on any worker that mishandles the material?
Good Answers: 58
06/29/2010 11:07 PM
If these are standard pressure cylinders, you will find they are very strong. If the caps are on snug, they will protect the valve. If the workers abuse the cylinders too much, mother nature will take over and thin the herd. The survivors will have a little more respect for pressure vessels. Just let nature take it's course, experience is the best teacher.
mike k
Good Answers: 60
Re: Composite Gas Cylinders
06/30/2010 9:36 AM
if cylinders have high presuure and they land on the valves you have an home made torpedo.
give them some sort of padded landing device.
whats the conditions like and i dont mean the weather,
pay, hours, accom etc ?
06/30/2010 10:09 AM
is not my employees they are the filling stations which they are covernment workers with very low salary but the problem in the country is that no one is responsible for his acts every one is answer if GOD wil.Like that you cant do anything.
In every job we have problems fighing for the quality.
06/30/2010 10:48 AM
"In every job we have problems fighing for the quality."
elgreko55 my friend, you have a firm grasp of the way things are, and a very clear way to say it.
Welcome to our forum. It is a pleasure to meet you.
Good Answers: 60
06/30/2010 1:53 PM
i understand that, but if anyones injured do they try and blame some else ?
It may even pay to set up a safe display of what could happen ie torpedo cylinders or a weakened cylinder that explodes to be put on national TV ?
07/01/2010 2:04 AM
or something like this video (courtesy of the intrepid MythBusters)
http://www.youtube.com/watch?v=ejEJGNLTo84
07/01/2010 3:45 AM
i beleive the top part of the external cover protects the cylinder valve.
As the cylindesr are light i beleive the handling will be more gentle than the heavy steel ones .This is the reason i need 2-3 samples to market and approve it.
Good Answers: 141
07/02/2010 12:39 AM
Composite? How about electrostatic loads safety and sparks? Or is it clay?
Plenty of room here
Register to Reply 11 comments
Anonymous Poster (1); Doorman (2); DVader1000 (1); dvmdsc (1); elgreko55 (3); mike k (1); peterg7lyq (2)
You might be interested in: Hydraulic Cylinders, Air Cylinders, Rodless Cylinders
