Previous in Forum: Composite Gas Cylinders   Next in Forum: Energy Consumption Comparasion of ARC vs Induction Furnace
75 comments
Water Pump
06/30/2010 7:19 PM
Hi,
Can anybody out there design a water pump for me that can pump water up a vertical incline of between 100 metres and 200 metres at the rate of 20,000 (yeah twenty thousand) gallons per minute? The primary challenge is that the pump must run on direct electricity (i.e no fuels) and the total energy consumption must not bemore than 20 to 50 KVA.(the less the better) Any ideas?? Funds are available to back any concrete and realistic design as long as verifiable diagrams can be provided. Always ready to discuss further details on request. Thanks
Pathfinder Tags: water pump
Re: WATER PUMP
06/30/2010 7:23 PM
Do you have OCD or what?
Re: WATER PUMP
06/30/2010 7:33 PM
Why would the answers be different this time from last time?
Does Guinness have a new category for most stubbornly unarithmetical question?
Re: WATER PUMP
06/30/2010 7:35 PM
Sounds like a huge waterpark.
Good Answers: 141
Re: Water Pump
06/30/2010 9:39 PM
You must have a design budget?
Plenty of room here
Re: Water Pump
06/30/2010 11:02 PM
Go onto the WWW and type in "FLYGT" and see your local supplier.
They supply pumps in all manner of sizes and this is easily inside their product range. They provided the pumps for the artificial whitewater course at the Sydney Olympic games.
The only "rider" on this is (and I'm not about to do the calcs) is whether 50kVA is enough energy to lift that amount of water through that height.
By the way, in relation to funding, I'd appreciate a 0.5% spotters fee for providing this information. You can contact me later with your bank account details. (This part is not a joke as some might believe.)
Re: Water Pump
06/30/2010 11:45 PM
Don't pay it. This guy missed out on the basic arithmetic this time, too.
(Which must be a momentary lapse, because he is usually quite knowledgeable.)
(Please don't take this badly; I've occasionally eaten my foot, too.)
(I have used Flygt pumps before, but I didn't know they went that large.)
Good Answers: 97
Re: Water Pump
07/01/2010 2:13 AM
We have surplus pumps that can do Imperial Gallons 800m down in a flooded mineshaft.
If you can withstand a PH of 2 - 4 you may have it. (or what is left)
Power consumption = zero at the moment - well within 50 KVA
Re: Water Pump
07/01/2010 11:16 PM
Can you please calculate how much Energy you need to do this?
Did you ask a pump vendor? What did they say?
Think you need to do more homework!
(ups did I just say that?)
Good Answers: 120
Re: Water Pump
07/01/2010 11:42 PM
just from gross mass calculations this will need from 2000 to 4000 HP for 100 to 200 meters, more or less.
DC motors are buyable for that use. Steel rolling mills buy them.
What is the use? wave park/water park
Per Ardua Ad Astra
Good Answers: 196
Re: Water Pump
07/02/2010 12:22 AM
GA, aurizon. This guy is over unity by a factor of 100 or more. Is this some kind of record for CR-4?
Ed Weldon
Re: Water Pump
07/02/2010 3:55 PM
I laughed when I first seen the original post, and reading the responses I was greatly entertained.
Then I read yours, then I started thinking. you bastard aurizona. and your right about the calculations....they are gross.
Ok, so because of that I'm going to share it with you what you made me start.
I'm adding more grossness to it, and not even calculate material thicknesses, size, valving or the massive foot print.
What if you do not use an electric pump to pump the water. but to prime the system.
And design a Siphon type of process. of course you would have to have it circulate alot more that 20,000 GPM, (30-40 times as much ?, now that is gross) and tap off the 20,000 GPM, of course you would run into problems of water supply and what to do with they water used on the down side........but that was not specified in the scope.....now was it.
And of course priming it would take a veerrry loonnng (coffee break) time.
It will not run for long as you keep tapping off the 20,000 gpm, your downside will ever decrease the effects of the siphon (the up lift), but that also was not specified in the OP scope either, as well as performance.
what else did I miss here......oh yeah, to build it, it will bankrupt your fancier, I mean your financier. I am glad that the budget was unclear.
p911
Re: Water Pump
07/02/2010 10:10 PM
Everybody is still saying what the text books said…. Can we throw them away for a bit PLEASE?? I received this on another forum…"What if there was a way to create some kind of vacuum at the top of the 100 to 200 metre pipe acting as a suction to draw up the water while at the same time complementing it with a pump at the bottom of the pipe. For argument sake lets say the total allowed power is increased to 100kw. Any ideas?? Comments?? What is the strength of vacuum that can be generated by the extra 50kw?? What if non returning valves were placed at intervals all along the length of the 100 to 200 metre pipe to reduce the weight of water being pumped up? Ideas?? Questions?? Comments??
To what exact height can a 50kw pumping mechanism pump 20,000 gallons per minute of water to?? 1metre? 2 metres??
Re: Water Pump
07/02/2010 10:51 PM
This is even sillier than than the original question. The most that a vacuum can "suck" water upward is 34 feet (~10.4 m). Check valves in the line do not decrease the weight of water between them. The maximum vacuum is 760 mm Hg ≈ 34 feet ≈ 10.4 m, as mentioned before. Extra kw may allow a more rapid approach to this maximum, but it does not increase the maximum. Vacuum technology is less efficient than simple pumps, anyway, and therefore requires more kw. Throw away the textbooks--are you kidding? And you claim to be a mechanical engineer? Good grief.
Re: Water Pump
07/03/2010 4:18 AM
I also like to add one thing about check valves is that it adds quite a obstruction to the flow.
Re: Water Pump
07/03/2010 4:26 AM
throw away the textbook? wtf......I think what you should do is actually open one up.Start with pre-algebra and eventually move up to physics.
Ok I'll talk your language. You can use the transporter prop from the star trek movie. ....you know the one where they transported the whales...Thats not in a text book.......and transport the water to the top....
Re: Water Pump
07/09/2010 2:22 AM
About 3 meters, depending on the efficiency of the pump.
The use of the word "exact" in your question is weird.
(One more wild guess, and you would have been close.)
Good Answers: 97
Re: Water Pump
07/02/2010 12:37 AM
Re: Water Pump
07/02/2010 12:42 AM
If this will o' the wisp were true, it would make pumped hydroelectric storage a massively over-unity system. So there is a greater incentive than water parks. I hope the poor OP doesn't waste another 20 years of his life on this wild goose chase.
Re: Water Pump
07/02/2010 1:42 AM
A basic calculation tells me that you need a minimum 3 MW motor to run this pump. Whereas you can have a motor of this rating, but your second condition of the question cannot be met under any circumstance. Even the no load losses of this motor will more than your specified energy consumption figures. Secondly, you may have to run the motor with a starting gear which will have its own energy consumption.
BBRaina
Good Answers: 54
Re: Water Pump
07/02/2010 1:59 AM
Let's work out how much energy you need using E = mgh & P = E/time
m = 20000 gallon/min = 1500kg/sec, g = 9.8m/s², h = 200m therefore E ≈ 3MW
Multiply that by some efficiencies and you'll need (guess) a 6MW electrical supply.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Re: Water Pump
07/02/2010 7:47 AM
I get aprox. 50kw
work done=1500 X 9.81 X 200=2943000 joules
power = work done /time taken
=2943000/60=49050 watts
motor usually runs better at 75% therfore get a 62kw motor
Re: Water Pump
07/06/2010 11:47 AM
ffej's calculations converted gallons/minute into kg/second. You correctly asserted that the amount of work done is 2.9 x 106 joules, but failed to follow the units and note that amount of work was performed in one second (not one minute). You then erroneously divided again by 60 seconds/minute, creating a 600% error.
Re: Water Pump
07/07/2010 7:20 AM
Yes you are right.(good job I don't do this for living!)
Re: Water Pump
07/02/2010 3:17 AM
The problem with these engineers is they're just not thinking outside the box-
To achieve this over unity engine all you need is about 200,000 of these guys with high voltage probes attached to their genitals.
Re: Water Pump
07/02/2010 8:23 AM
Someone has mentioned Flygt.
You could also try flowserve, Weir, KSB or even Caterpillar who do large firepumps but they may only do diesel powered. i do not have their contacts to hand but they are all on the net.
Re: Water Pump
07/02/2010 10:15 AM
I believe that a peristaltic pump will best suit your needs.
Re: Water Pump
07/02/2010 11:16 AM
Lol 20,000 gpm at 300 to 600 feet of lift
Re: Water Pump
07/02/2010 11:02 AM
What is your power source? Maybe you're asking the wrong question. Instead of trying to perform an impossible act, maybe you should be asking for advice on other means of generating enough power to drive this massive pump. With unlimited funds you could set up a sweet array of wind turbines.
"Obviously you're not a golfer." - The Dude
Re: Water Pump
07/02/2010 11:48 AM
The energy consumption is pretty well fixed, it takes a certain amount of energy just to lift the water at the specified flow rate against the specified head, then you can figure losses between the motor and pump (pumps alone have efficienciesrange from the 40s to about 92, typically in the mid 80s is preferred design operating points) such that you might get a total efficiency for pump and motor in the mid 70% to 80% range (depending on operating points on curve). You can not move water without the energy input. You would need a minimum energy input just to move the water, of about 1340 kW with 325 feet of lift and 30 feet of system pressure (this is just the energy that must be imparted to the water, more needed for the system losses in motor and pump). No matter the pump, you will always need that minimum energy just to move that water. So unless you augment the electrical supply somehow, you can not do it.
If you can find the energy, then I would suggest go to any pump supplier, there are many-Gould, Cascade, Flygt, Floway, etc.. the system design requirements such as low flow needs, pressure, peak delivery, etc. would be necessary. Depending on site, you may have other considerations such as pump control, vfds, multiple or specialized pumps (though 20,000 gpm is not very much flow, about 45 cfs), you can go to a engineering firm like AECOM to get those designed. Bosserman and Tchobanoglous, two of the authors of the standard Pump design Text were employee and AECOM (formerly Metcalfe Eddy and Boyle Engineering) publishes their products still. Just going to be a series of centrifugal pumps.
Good Answers: 123
Re: Water Pump
07/02/2010 2:03 PM
Yes, but the falling water could be harnessed to produce all the energy to run the pump, and then some.
Bob
Re: Water Pump
07/02/2010 3:04 PM
more energy out of moving water up hill than you put in, now that would be a trick. I think you have jsut solved the worlds energy problems.
Good Answers: 123
Re: Water Pump
07/02/2010 10:49 PM
No No No. You have it backwards. There is more energy in the falling water than it takes to pump it up. The other would be over unity. And we all know that is impossible.
Bob
Re: Water Pump
07/02/2010 1:06 PM
I think you dont need design anything.Did you try any supplier?
Re: Water Pump
07/02/2010 2:00 PM
A supplier will only supply a pump not the control structures, valves and other ancillary components. Plus they could never pump the water for the energy he is desiring, though they would likely try to sell him a pump system with a limitation on the guarantee.
Re: Water Pump
07/02/2010 10:06 PM
Everybody is still saying what the text books said…. Can we throw the books away for a bit PLEASE??I received this on another forum…"What if there was a way to create some kind of vacuum at the top of the 100 to 200 metre pipe acting as a suction to draw up the water while at the same time complementing it with a pump at the bottom of the pipe. For argument sake lets say the total allowed power is increased to 100kw. Any ideas?? Comments?? What is the strength of vacuum that can be generated by the extra 50kw?? What if non returning valves were placed at intervals all along the length of the 100 to 200 metre pipe to reduce the weight of water being pumped up? Ideas?? Questions?? Comments??
Good Answers: 141
Re: Water Pump
07/03/2010 12:24 AM
Are you sure you do not want this? I think it is for sale.
Plenty of room here
Re: Water Pump
07/03/2010 12:43 AM
Okay, so what is this? A locks that doesn't go anywhere, or something else? Price = ??
Re: Water Pump
07/03/2010 1:02 AM
This is a water lift. And sometimes as you see there is a boat in it. It is waste of money, because it is hardly used. There is space for a lot of ships in it. Every time Flanders makes an investment, the Walloons want compensations for the same amount of money. That creates "useless, but working monuments" in Belgium.
Good Answers: 141
Re: Water Pump
07/03/2010 1:26 AM
here is more - I hope the translation is still present: http://www.reisimpressies.eu/belgie-scheepslift.htm enjoy. D
Plenty of room here
Re: Water Pump
07/03/2010 2:01 AM
That's the most amazing floating wetdock I have ever seen. Is there hidden behind it a canal that conveys the boats over to yonder hill?
Re: Water Pump
07/03/2010 8:41 PM
you have a sealed mind. The mind of a man who believes he knows it all, BECAUSE he has read it all. great ideas need minds of people who wish to write the books for guys like you to read. You would be great to keep things running as you obviously are horrible at starting it running. No offence meant, just how I've percieved your comments
Re: Water Pump
07/03/2010 10:45 PM
That might have been sort of relevant as a reply to my post 28. But it has nothing whatsoever to do with post 35. Either way, your post is both false and stupid. Your idea violates some really simple facts of physics, and therefore you will never get it to start running, nor to keep it running. But if you want to waste another 20 years on it, far be it from me to stop you.
Good Answers: 141
Re: Water Pump
07/03/2010 11:44 PM
Dedayomi: We all have dreams, some can be fulfilled, some not yet. Your idea will need to wait until the earth loses some gravity. Pumping the quantities within your proposed budget is not achievable. But don't give up. Maybe there are other opportunities if we get to know all the details.
Plenty of room here
Re: Water Pump
07/04/2010 11:10 AM
just be aware.....some dreams are not all good. some dreams turn out to be nightmares.
Good Answers: 141
Re: Water Pump
07/04/2010 11:35 AM
Tell me! was just mentioned to keep thinking.
Plenty of room here
Re: Water Pump
07/07/2010 10:40 PM
I appreciate your response. The fact is that I know all the basic physics theories but I just cant help the feeling that we're all missing something....... Its like just out of touch... there...somewhere... somehow.. You see its not about the number of pumps used, or the particular method used, its about keeping the power consumption to the barest minimum
Re: Water Pump
07/08/2010 12:06 AM
You say that you "know all the basic physics theories." Then please share your knowledge by showing your calculations of how 20,000 gpm can be pumped 100-200 m vertically upward with 20-50 kw. Hidden calculations are not honest unless you furnish them later.
Re: Water Pump
07/08/2010 9:23 PM
how I honestly wished that question deserved an answer...! How I wish!!! Isn'tthat why you've been writing for the past week or so?? If it was part of any basic theory even a @**skull like you would know it!
Re: Water Pump
07/08/2010 11:19 AM
Actually, barest minimum is an incorrect statement, you are asking for power consumption substantially below the minimum necessary just to lift the water (not a question of efficiency).
Re: Water Pump
07/08/2010 9:28 PM
... Sure!..so maybe the question is what is the barest minimum as we know it now and how can we beat that?? by that I mean reduce it even if by 1 watt, if someone can think of a way to reduce this "barest minimum" by 1 watt then maybe it would open other minds as to ways of reducing it further....
Re: Water Pump
07/09/2010 1:46 AM
Forget about the work rate (i.e. power) for a while just consider the quantity of work. The barest minimum is = mgh
you cannot do it with less. With improvements in efficiency you can get close to that quantity, but, you cannot do any better.
Re: Water Pump
07/03/2010 11:07 AM
Wouldn't it make more sense to put a booster pump in line, around the 1/2 to 2/3 mark instead of making one pump do all the work. The second pump would surely take some work load off of the first pump......of course the pumps would have to be sized properly...my 2 cents
United States - Member - American all the way Hobbies - Target Shooting - Aint nuthin like killing an innocent soup can!!!
Re: Water Pump
07/03/2010 6:17 PM
You might look into some of the pumps that are feeding irrigation systems off of the Snake and Columbia rivers in the Pacific Northwest.
I don't know if they match your specs, but they push a lot of water over the hills to farmland all over eastern oregon, washington, and idaho.
Give me enough duct tape and I can fix anything!
Good Answers: 120
Re: Water Pump
07/04/2010 8:06 AM
Here is another problem for you if you solve the OP one.
Gold from sea-water. There is a large amount of gold dissolved in the oceans.
The problem is the dilution.
The energy cost required to pump the water up 1 meter exceeds the value of this gold, yet the amount of gold is enormous.
from wiki
The world's oceans contain gold. Measured concentrations of gold in the Atlantic and Northeast Pacific are 50–150 fmol/L or 10-30 parts per quadrillion. In general, Au concentrations for Atlantic and Pacific samples are the same (~50 fmol/L) but less certain. Mediterranean deep waters contain higher concentrations of Au (100–150 fmol/L) attributed to wind-blown dust and/or rivers. At 10 parts per quadrillion the Earth's oceans would hold 15,000 tons of gold[43]. These figures are three orders of magnitude less than reported in the literature prior to 1988, indicating contamination problems with the earlier data.
A number of people have claimed to be able to economically recover gold from sea water, but so far they have all been either mistaken or crooks. A so-called reverend, Prescott Jernegan ran a gold-from-seawater swindle in the United States in the 1890s. A British fraudster ran the same scam in England in the early 1900s.[44] Fritz Haber (the German inventor of the Haber process) did research on the extraction of gold from sea water in an effort to help pay Germany's reparations following World War I.[45] Based on the published values of 2 to 64 ppb of gold in seawater a commercially successful extraction seemed possible. After analysis of 4000 water samples yielding an average of 0.004 ppb it became clear that the extraction would not be possible and he stopped the project.[46] No commercially viable mechanism for performing gold extraction from sea water has yet been identified. Gold synthesis is not economically viable and is unlikely to become so in the foreseeable future
Per Ardua Ad Astra
Good Answers: 123
Re: Water Pump
07/04/2010 1:31 PM
Are there any areas that have heavier concentrations of gold? The thought of plating comes to mind. Would it be possible to use localized electric probes (low voltage) to transfer the gold to cathodes?
Bob
Re: Water Pump
07/07/2010 10:47 PM
I think the comments/ comparison to gold in the ocean is trivialising the whole exercise. The fact is I feel maybe we're missing something somewhere, maybe a combination of all these factors (vacuum pumping, peristaltic pumps, multiple pumps usage, etc etc can lead to a situation whereby the total energy used in pumping up water reduced to a minor fraction of what is used as we all know it now....
Re: Water Pump
07/04/2010 11:18 PM
I've read enough to know that I cannot be of any assistance on this thread and am going to drop it. Seems that our new friend is not yet open to share the collected wisdom that exists here.
My suggestion to the originator is to re-visit the basics of physics relating to motion and energy, then to visit the physical properties of water.
There are some things, whether written in a book or not that just happen to be. Energy balance discussions, vapour pressures and vacuum. Until these are understood there will be struggles in your mind.
Maybe this quest will assist you to discover the same truths that many here are trying to share with you and your passion for truth will then enable you to assist others.
Re: Water Pump
07/05/2010 9:24 AM
Nnoo, noo, you think with a close mind.....said sarcastical
he wants people to give him the answers he wants to hear.
Re: Water Pump
07/05/2010 5:37 PM
I was going to put together a scenario that he could "pump" 20,000 gallons of water (vapour) using the nominated energy, but that would just use tooooooo much of my energy. Would that qualify as an answer? , but then that would take me to places I don't want to go. The enthusiasm shown is great and once he finds true direction and the means to evaluate his proposals there are possibilities.
There are others here that are willing to digest the feedback they receive and move forward.
As I hinted in my very first post, there was a feel that the energy equation needed review. From what I've now seen, he is likely to put the pumps at the top of the hill (so they will be easy to service) and use 300mm pipe (since that costs less) and also make a heap of other fundamental errors relating to the physics involved in this project.
I just hope that whoever has the investment potential that he mentioned has enough nouse or due diligence review to find the other more subtle flaws that are bound to be included in the project.
Heck, the thrust blocks for the pipes and any bends would need to weigh many tons and be specifically designed for the terrain.
The turbulence of the water exiting the pipes would erode most structures in short time.
To help him beyond this point (in my mind) is actually creating a dangerous scenario where other things are bound to go wrong in a very spectacular way.
By the way, thanks for the comment.
Re: Water Pump
07/11/2010 9:09 PM
..... is there anything that could be done to the water to make it lighter so the pump's work load is reduced? Of course this needs to be done with as little poweras possible...
In reply to #60
Re: Water Pump
07/11/2010 9:54 PM
Boiling it would make it less dense, but the weight would still be the same. The power required to do this would be much greater than the pumping power, which is already adverse. Sorry, no joy in that approach, either.
Re: Water Pump
08/15/2010 9:43 PM
Can a solar powered pump do this work? using solar energy?? What would be the constraintsis there any solar power /pump company that may be recommended??
Re: Water Pump
08/16/2010 12:31 PM
Sure if you have the land available to develop a sufficiently large enough solar array, and depending on the configuration can operate the pumps during day light hours and provide storage for the non-daylight periods plus overcast and low energy days.
Re: Water Pump
08/16/2010 2:55 PM
You'd need about 12,000 square m² of solar panels at a cost of about $20,000,000.
In reply to #64
Re: Water Pump
08/17/2010 10:31 PM
Could you please give more details about your estimation and costs??is it based on facts/experience. Could you kindly expantiate further?? and could you recommend a REPUTABLE firm/company that I can talk to on developing the solar alternative or at least examine this option further??.The funding is not really an issue if we're assured of desired results. Thanks
In reply to #65
Re: Water Pump
08/18/2010 1:02 PM
20,000 US gallons per minute = 1262 litres per second = ~1262 Kg per second
energy required = mgh = 1262 x 9.81 x 200 = 2,476,044 joules per second
which is 2,476,044 Watts
solar panels are at best 20% efficient so you need 5x 2,476,044 watts of insolation
= 12,380,220 watts of insolation
You'll be very lucky to get 1KWatt of insolation per square metre so that's
12,380 m² of solar panel
It turns out that the above estimate is probably an underestimate: solarbuzz reckons you will pay about $4 per watt
So that's about $50 million.
I haven't factored in the efficiency or cost of the pumps.
In reply to #66
Re: Water Pump
08/18/2010 1:12 PM
There is also the efficiency for solar radiation received, even just in the western US this varies widely from a place like Pheonix to someplace like Seattle. The difference in latitude, the days of overcast, etc. all impact efficiency. Let alone extending this to some place like India. Then there are efficiencies of power transmission, control and storage, temporary storage to provide supply relative to demands, etc. that effect sizing of systems and cost. Best I think you can really estimate is the magnitude of the cost between $10 million and $100 million.
Re: Water Pump
11/15/2010 1:31 AM
Hello dedayomi,
A novel and very simple positive action pump designed for large volume and high head was developed some years ago.
This pump involves having gas pressure force liquid.
The extremely high pressure forces of some gasses at very little heat is long been researched, plus heat may be sourched from electric element.
Should you know of the bar pressure needed to raise one litre of water to a 300 meter head figures can be supplied much quicker.
Most interesting post.
Off to do research.
Cheers
Peter
Re: Water Pump
11/15/2010 3:04 AM
Hello dedayomi,
Your thread does have me captivated.
Research, it takes one pound pressure to raise a collum of water 2.304 feet.
200 meters is 650 feet. 650 pound pressure is required to raise water from bottom to top.
650 pound is 45.77 Bar.
Reactive gasses can easily supply that pressure for very little heat.
Gas flow volume would need be 333.3r gallons per second. Cooling the gas to start temperature also needs take place in that time.
A temperature difference of 6 degrees in Carbon Dioxide gas supplies all pressure needed.
The power draw on an electric element to acheive the heating is unknown.
Cheers
Peter
In reply to #69
Re: Water Pump
11/15/2010 12:13 PM
No matter what it always takes at a minimum, minus the efficiencies losses (and gas systems have huge efficiency losses), γQH divide by some conversion factor for units (E.G. 550 for Horsepower) of power to move the water. If H is 650 feet, Q is the flow rate in cfs, γ is 62.4 pcf the unit weight of water, then the minimum power to move the water can be calculated. This minimum can not be circumvented.
In reply to #70
Re: Water Pump
11/16/2010 3:33 AM
Hello RCE
Thank you for your reply. Sorry I not understand your figures.
My work is in supplying gas pressure to pump water.
333.33r gallons of water per second are required at a head of 200 meters.
This would require a working gas pressure of 45 bar.
I gallon of recyling gas per second is needed to raise one gallon of water per second to a 200 a meter head.
The elecrtrical wattage needed to raise the temperature of 333.33r gallons of gas 5 degrees Celsius in one second, I am hoping to find out.
Should such be under 50 megawatts then we are laughing.
Cheers
Peter
In reply to #71
Re: Water Pump
11/16/2010 11:30 AM
The equations I presented are just the base power demand to lift water, without efficiency losses. this doesn't count losses in electrical systems, energy transfer to mechanical systems and frictional losses in the mechanical systems themselves (i.e. gas lift systems are mechanical lifting also).
In reply to #72
Re: Water Pump
11/16/2010 9:03 PM
Hello RCE
Fully agree with you.
My interest in the post come from having gas force a hydro turbine to generate electricity.
Conventionaly heat for the boiler comes natural or by fuel.
I be absolutely lost to know how much electricity is required by a heating elelement to increase by 5 degrees the temperature of 1 litre Carbon Dioxide every second.
Base temperature of 30* C raising to 35* C.
Once that is known the Kwa of the water pumping is easily calculated.
Cheers
Peter
In reply to #73
Re: Water Pump
11/17/2010 12:39 PM
Well the CP,m for CO2 is 36.94 J/mol-K, and the CV,m for CO2 is 28.46 J/mol-K. You will need the operating pressures to calculate the energy required to raise the temperature 5 K. Because energy transfer efficiencies are better into more highly pressurized gases, i would assume you would want the pressure as high as possible for your system to absorb the heat as fast as possible thus requiring the heating element use less electricity per mole of CO2 heated. Knowing the molar flow rate and the temperature change you can estimate the joule energy required, which is an easy conversion to kW. As for the rate of transfer of energy, CO2 is well defined in chemical engineering literature, research it as a coolant and that should provide some curves on the energy transfer rates relative to pressures and elements used.
In reply to #74
Re: Water Pump
11/18/2010 1:49 AM
Hello RCE,
My sincere thank you for the information, I see you are quite well learned. However I personaly have no understanding to matters of which you speak.
It may be that you be of greater assistance than I to the poster. The attached possitive action pump operating on two one way valve and a floating sphere is Open Technology free to copy.
This we get into operation by heating the Co2. Cooling is acheived by Co2 depressurisation at exhaust.
The attached is working example. The pressure data supplied is not one however that we have yet had it working at, and figures are entirely the pressure to heat value so obtained from the Internet. The electricity production is by California University school of hydro electric power generation using an 80% efficient turbine.
Thank you again.
Cheers
Peter
Register to Reply 75 comments
Anonymous Poster (5); aurizon (2); BB Raina (1); bob c (3); bwire (1); DaS Energy (5); dedayomi (10); draco (1); dvmdsc (5); Ed Weldon (1); farmatt (1); ferquiza (1); ffej (1); Hendrik (1); Just an Engineer (3); lyn (1); pauls_14 (1); phoenix911 (5); Randall (4); RCE (10); Rescue (1); snuf (2); Tornado (10)
