Previous in Forum: Desal Conductivity Issue   Next in Forum: Commercial Kitchen Water Heater Overflow.
DHT and ISR
06/30/2010 4:03 AM
What is the obvious difference between DHT(Dehydrogenation Heat Treatment) and ISR(Intermediate Heat Treatment)?
Re: DHT and ISR
06/30/2010 5:35 AM
If it's obvious, why are you asking? Is this a quizz? A trick question, perhaps?
_____________________
69
Re: DHT and ISR
06/30/2010 8:27 AM
Look here
Re: DHT and ISR
06/30/2010 5:25 PM
thank you
Re: DHT and ISR
06/30/2010 5:21 PM
sorry, ISR(Intermediate Heat Treatment) is incorrect, ISR(Intermediate Stress Relief) is correct
Re: DHT and ISR
10/07/2010 7:06 PM
The obvious differences between dehydrogenation heat treatment (DHT) and intermediate stress relief (ISR) are temperature and governing documents.
Most ISRs are controlled subcritical heat treatments performed at temperatures within 100 oF to 200 oF below the metal's lower critical temperature, in accordance with Code requirements (e. g. ASME BPVC) at temperatures between 1100 oF to 1350 oF, depending on the metal's ASME P-No. classification (carbon and alloy content).
DHT's, on the other hand, are performed for the sole purpose of hydrogen removal, generally at temperatures between 600 oF to 800 oF for times recommended by such technical guidelines as "Welding Steels Without Hydrogen Cracking" by N. Bailey, et. al. depending on metal thickness.
Anonymous Poster (2); mkbj1205 (2); tsidt (1)
