Previous in Forum: DHT and ISR   Next in Forum: Commercial Kitchen Floor Sink.
Commercial Kitchen Water Heater Overflow.
06/30/2010 11:34 AM
You have a 100-gallon commercial water heater. To provide for the expulsion of any overflow water due to the rare tripping of either the over-temperature relief valve, or the over-pressure relief valve (same 3/4" exit pipe), you have two choices.
1. Provide a floor drain with a trap, connected to the kitchen sewer line.
2. Route a pipe to an exterior wall, with a minimum slope of say 1/4" per foot.
No matter how convoluted the route may be, #2 is preferable, because when the water in the trap dries out, the offensive sewer gases will emanate thru-out the interior. Correct?
Good Answers: 299
Re: Commercial Kitchen Water Heater Overflow.
06/30/2010 2:04 PM
No, not entirely
This is an image of a self-priming trap. It uses the waste water from a nearby sink to constantly (whenever the sink is used, anway) trickle a little water into the seldom used trap, thus preventing the familiar unpleasant sewer odor from entering your place.
07/01/2010 5:45 PM
some plumbing inspectors require "trap primers" to keep the trap full. Piping the pop off to outside in cold climates can drip and freeze up tight. On new construction "day light" drains, into the French drains can be used, thus a sewer back up will not flood the floor from the floor drain tied into the sanitary sewer. Also, codes require an air gap ( 1 " ) so there can not be any cross connection between drinking water and polluted water. ( plus, you can see a pop off dripping and take care of it right away.
Also, in a 100 gal. water heater, there is allot of pounds per square inch (let's say 50), so how many sq. " are inside the tank? Thermal expansion is as strong as ice and will explode the tank, so pop offs, maintained properly are a MUST Hope this
helps,,cheers.
Register to Reply 2 comments
