Previous in Forum: Sony Vegas Rendering   Next in Forum: Diary or Booking Software Required
9 comments
Windows 7, Rockwell FactoryTalk, Virtual Machine, PLC
07/01/2010 8:30 AM
I started with a new company and they gave me a Dell Vostro lap top with Windows 7 installed. The trouble is that I need to use Rockwell's PLC suite with FactoryTalk HMI for development and parts well not load onto 7 at all. I suspect that Siemens Step 7 and WinCC will have similar problems.
I installed MS virtual machine from the MS web site with XP pro but found that some of the FatoryTalk components can not tolerate the environment. The Rockwell tech support suggested VM Ware's virtual machine will work far better, but still they know that some of the network configurations are iffy. Rockwell will not likely have a new release out for 7 for months.
Does anybody have any experience with this problem and is VM Ware's Workstation 7 a viable solution? Will I have to replace Windows 7 with XP pro to get the required functionality?
Re: Windows 7, Rockwell FactoryTalk, Virtual Machine, PLC
07/01/2010 10:17 AM
You may have the wrong version of Doze 7. Ultimate and Pro offer XP compatibility. Home does not.
But since you didn't tell us, we cannot assist fully.
07/02/2010 7:55 AM
The native OS is Windows & Professional. The virtual OS is XP Pro.
07/01/2010 1:02 PM
If you can, XP is the way to go. Even after Rockwell comes out with a version that is compatible in 7 months, will Siemens and the others? Add to that the fact that the first go round on any software for a new OS is buggy as hell, and it just isn't worth the risk until things get settled a bit.
Put another way: I want my software to be leading edge, but not bleeding edge.
Good Answers: 97
07/02/2010 1:53 AM
Of course Siemens and the others will windows 8 is way out around the bend yet.
Location: Move between Pakistan, Singapore, UK, and Canada
07/01/2010 2:43 PM
Are you using 32 bit or 64 bit base OS ? Also Windows 7 might need Rockwell to define new workflows, especially to support UAC. The better option would be XP on VMware, even better would be to use 64 Bit base Windows 7 OS with XP VM. Use NAT for network support, and that will be the safest, your VM will actually run just like your base environment.
Also note that VMware does nothing but simulate your underlying hardware, to technically using VM is no different than using a base OS, and it is much cost effective.
Good Answers: 97
07/02/2010 2:03 AM
As SimS has stated w7 64bit is preferable though XP 32bit is preferable; yes there is a 64bit XP version but XP was designed for 32bit.
In disk management create a new partition make it about 48128MB and install XP to this partition. When you boot the computer you will choose which O/S to boot to.
As the vendor softwares catch up you should begin to use w7 instead of XP or you may be catching up not far down the road
07/02/2010 7:16 AM
I am currently running Windows 7 with an XP VMWare and all seems to work pretty well. Prior to this laptop I had a Vista machine with Virtual PC and had pretty good luck with that for Rockwell software as well. Not sure what kind of networking issues your having. I regularly connect via ethernet to Compact and ControlLogix PLC's. Have also used RSNetworx for DeviceNet and ControlNet with the VirtualPC without problems.
Shawn
07/06/2010 7:50 AM
My biggest problem was with FactoryTalk, it would not allow me to run the directory create application because it thought it was being run from a remote terminal. RSLogics and RSNetworks all seemed to work fine. The big issue is FactoryTalk.
07/02/2010 12:00 PM
Hello RickLee,
I run Windows7 Ultimate on my laptop... and I have a whole variety of VMWare Virtual machines from Win3.11 to Win2k8 Server. With proper resource allocation, I have NEVER had an issue running anything within a VM.
No secret, I work for Wonderware... and I have used VM's from local presentations to WebServers... connected to a MULTITUDE of hardware devices from RTU's, to ControlLogix PLC's, to Distributed Control Systems (DCS). Any networking issues can be resolved. I would recommend running the software on a VM that it supports. If it requires multiple VM's running at the same time, so be it... just have adequate resources to dedicate to them. VM's can communicate with each other quite nicely.
Right now, as I type, I am running a Win2k3 Server VM, an XP Pro VM AND a Win2k8 VM on a Dell m6500 i7 with 8G of ram (Win7 Ultimate 64 bit host)
My advice, spend the money for VMWare Workstation 7.1 and do what your heart desires. Without workstation you cannot "create" the VM's. Also, you need to be particular with distributing VM's you create. Each requires it's own valid license, as if it were it's own computer... this includes the OS.
I'll be happy to help you navigate the issues... can even provide a friendly ear in your geography.
thx - Rudy
Register to Reply 9 comments
Anonymous Poster (1); bwire (2); Kilowatt0 (1); RickLee (2); Shawn33 (1); SimS (1); WWSysCon (1)
You might be interested in: Linear Shafts, Rotary Shafts, Hardness Testers
