Previous in Forum: Highway Safety   Next in Forum: Leslie E. Robertson Associates (LERA)
Sewer Line Slope
07/02/2010 10:33 AM
Lou have a 2% slope on a pipeline. That equates to a drop of 2 ft / 100 ft, = 0.02 ft / ft, = 0.24 in. / ft; correct?
Re: Sewer line slope.
07/02/2010 10:51 AM
Yep. One-quarter inch per foot (approximately).
07/03/2010 10:44 AM
Good morning Guest.
So, for in the US, in the earth under the floor of a single story building, carrying the waste of 3 WC's, a urinal, and 4 lavs, in DFU's of 6, 6, 6, 2, 1, 1, 1, 1, or a total of 24 DFU's, you'd specify a 4" size, because a 3" can only support 20 DFU's, per the IMC P62, correct?
And this pipe would be 4" SDR 35 (0.120"wt), 4.215" OD PVC, at 2% slope, or 1/4" / ft, and not 4" Sch 40, 4.5" OD PVC, correct?
It seems a little surprising the industry did not just specify the Sch 40 for the extra strength it would provide, but I guess the cost differential was enough to justify this thin-wall, special OD pipe and fittings.
Good Answers: 119
Re: Sewer Line Slope
07/04/2010 3:52 PM
The numbers I've typically seen for required drain slope are :
a minimum 1/4" per foot (2%) slope for 3" diameter or smaller
a minimum 1/8" per foot (1%) slope if larger than 3" diameter
however, please verify the correct numbers with your local plumbing inspector. He should be familiar with your local code requirements and will be the one who passes or fails your installation! Local and regional codes usually start with the larger UPC/IPC standards, but many supersede them with stricter requirements.
07/06/2010 11:21 AM
you are correct! Figures don't lie only liers figure
Register to Reply 4 comments
Anonymous Poster (1); flyinghigh (1); mjb1962853 (1); Robert Laurin (1)
