Previous in Forum: Lightning Protection Near Gas Vent   Next in Forum: 3-Phase High KA Reading
Maximum Acceptable Tan Delta Value of 132KV SF6 Circuit Breaker
07/04/2010 1:09 AM
Dear All,
May I get answer of "what is the maximum acceptable tan delta value of 132 KV sf6 circuit breaker? "
Your valued reply would be highly appreciated>
Regards.
Rashid
Good Answers: 131
Re: Maximum Acceptable Tan Delta Value of 132KV SF6 Circuit Breaker
07/05/2010 7:38 PM
If I recall correctly, calculating a tan-delta (or insulation power factor) value of an SF6 circuit breaker means very little, because the leakage currents (usually in microamps!) are usually so small small that even slight measurement errors cause large variation in calculated results. The better measure of condition is to compare test values between the poles of the breaker, and with values from comparable breakers.
07/06/2010 4:54 AM
Thanks a lot for your reply. May I get typical maximum acceptable tan delta value for above mentioned 132 kv sf6 circuit breaker.
rashid
07/07/2010 5:45 AM
IT can be from 10pf to 10 micro farad depending upon features which are not in itsef binding but are design factor dependent.
Knowledge sharing is a WIN-WIN situation
Anonymous Poster (1); mountk2 (1); PeterT (1)
