Previous in Forum: Machinery   Next in Forum: What Would Happen If One Jet Engine Failed
How to Select Filler Rods For Welding Similar & Dissimilar Metals
07/05/2010 4:15 AM
Dear CR4 Members,
I am involved in maintenance of Boiler pressure parts, kindly help me by providing some sort of ready reckoner for selection of filler rods for welding similar & dissimilar metals. Eg. SA 210 GrA1 to SA 210 GR A1, SA 213 T11 to SA 213 T22, SA213 T22 to SA 335 P22.
With Regards,
Chella
Re: How to select filler rods for welding similar & dissimilar metals
07/05/2010 7:45 AM
In case you are working on PV- these answers are to be strictly in line with ASME PV Codes.
However the question asked imply you do not have the relevant WPS (let us forget about hence the PQR and WQR)
07/05/2010 12:04 PM
Do not carry out welding on boiler parts without access to the correct code of practice for the job. The requested 'ready-reckoner' will be found within them!
Re: How to Select Filler Rods For Welding Similar & Dissimilar Metals
07/06/2010 1:13 AM
A welder will confuse you with all sorts of technical jargon, however, I worked in a food processing plant a few years ago, and had a cracked black iron steam pipe that had to be pressurized in a few hours.
I first ground the valley and then welded it with 7018 stick, then reinforced it with 6013(or 6011, Hey, it's been over five years!).
It held for the year that I worked at that plant!
I don't remember procedure, but if I check my base metal, watch my puddle and my heat I do OK (Translation, nothing I've done has broken yet!).
All I can say is find some scrap pieces and during your breaks practice, practice, practice and practice some more until you get it right, and get a trusted welder friend to evaluate your work. I did, and I wound up doing all the "emergency" fabrication projects in the processing plant. many of these projects should have been weekend jobs, but I learned to adapt.
What defines us is how well we rise.....after falling.
07/06/2010 6:02 AM
My dear, the OP is planning to work in pressure vessels.
The so called jargons are necessity here since the equipment costs are in millions of dollars and there are human lives waiting to be compromised due to a single bad welding.
07/06/2010 9:20 AM
WHOA WHOA, we're talking about welding boiler pressure parts, not a bar b que. OP, might I suggest you speak with some of the senior members at a welding trade school if you're really curious about this? I think that would be a good start. Ask about specs, any possible licenses or certifications for the weld (and welder). Do you have to perform any NDT on the weld afterwards, those sort of things. It seems, unfortunately, that you're getting anecdotal advice here. Thats like NASA going to the moon in the 60's and some guy in his garage is 'recommending' to "just shoot the rocket in that direction..."
DISCLAIMER:
No offense is meant in the direction of any other poster on this thread, or anyone reading this thread, or anyone else, or any baby seals. Mosquitos okay, but not baby seals..
Good Answers: 18
07/08/2010 10:33 AM
Basically speaking there are 7 classes of filler metals or electrodes which can be used for joining dissimilar steels or their various combinations and the types are given in the bracket.
1. Carbon steel to Carbon steel or up to 1.25 Cr-0.50 Mo (E 7018* or E 7016 for SMAW and ER 70S-2 for TIG process)
2. Carbon - 0.5 Mo to same or up to 1.25 Cr -0.50 Mo (E 7016-A1 or E7018-A1 for SMAW and DIN 8575 - ER SG Mo for TIG process)
3. 1.25 Cr- 0.5 Mo to same or up to 2.25Cr-1.0 Mo (E 8016-B2 or E8018- B2 for SMAW and DIN 8575 - ER SG Cr Mo 1 for TIG process)
4. 2.25 Cr-1.0 Mo to same or up to 5Cr-0.5 Mo (E 9016-B3 or E9018-B3 for SMAW and DIN 8575 - ER SG Cr Mo 2 for TIG process)
5. 5.0 Cr - 0.50 Mo to same or up to 9Cr-1.0 Mo (ER 502-15 type only)
6. 9.0 Cr - 1.0 Mo to same or up to 7Cr-0.50 Mo (E 505-15 type only)
7A. For cyclic services where PWHT is to be used - (Inconnel type 75Ni-16Cr-7Fe)
7B. For non cyclic applications above 4300C (310 - 25Cr & 20 Ni or 309 - 25Cr & 12 Ni as an alternative to above)
7C. For non cyclic applications below 4300C (310 - 25Cr & 20 Ni or 309 - 25Cr &12 Ni is used).
Type 309 with 20 Cr & 12 Ni is more suitable than type 310 for dissimilar material welding
In your case:
a. for welding SA 210 GrA1 to SA 210 GR A1—
(P1 Gr 1 to P1 Gr.1 -smls. tube - ER 70S-2 for TIG / E7018 for SMAW)
b. for welding SA 213 T11 to SA 213 T22 –
(P4 Gr 1 to P 5A to Gr 1-smls. tube - DIN 8575-ER SG Cr Mo 1 for TIG / E8018- B2 for SMAW )
c. for welding SA 213 T22 to SA 335 P22 --
(P 5A to Gr 1-smls. tube to P 5A to Gr 1 smls pipe -- DIN 8575-ER SG Cr Mo 2 for TIG / E9018- B3 for SMAW)
DIN 8575 ER SG Cr Mo1 (1,25 Cr-0.5Mo) & ER SG Cr Mo2 filler wires (2,25 Cr-0.5Mo) are the nearest available filler metals for TIG process..
Trust above details will help you to plan the welding of various materials.
Sridhar.
What we have done for ourselves alone dies with us: while what we have done for other and the society remains and is immortal.
07/19/2010 2:43 AM
SIR,
IAM WORKING IN BOILER PR PARTS AND I WANT THESE FILER MATERAILS CORRECT OR NOT ONCE U WILL CHECK THIS AND SEND CORRECT FILLER WIRES AND ELCTRODES AS EARLSY AS POSSIBLE.
1.FOR SA-106B,SA-210 A1 MATERIALS(CARBON STEEL),IAM USING E7018/ 80SD2.
2.FOR SA-335 P22,SA-335 P12 MAERIALS(ALLOY STEEL),IAM USING E8018 B2/ 90SB2.
3.FOR SA213 T22,SA213 T12 MATERIALS,IAM USING E8018 B2/ 90SB2.
4.FOR SA213 T91 OR P91 MATERALS,IAM USING E9018 B3 OR B9 / 90SB3 OR B9.
MY EMAIL ID:angirekula_vasu@yahoo.com
Register to Reply 7 comments
Anonymous Poster (3); Jason something (1); PWSlack (1); Redfairlane (1); SRIDHAR (1)
