Previous in Forum: Max Allowableable Stresses for Materials   Next in Forum: Power Engineering - Bits
8 comments
Valve Trim
07/06/2010 7:39 AM
hi friends,
any one can help me to give me the exact definition of valve trim and what are the different parts that comes under this?
thank you.
Re: Valve Trim
07/06/2010 9:08 AM
Check-out the article in Wikipedia on globe valves and start from there.
Re: Valve Trim
07/06/2010 9:56 AM
Are you studying for an exam? That's quite a flurry of questions from you.
Some explanation of your motives might yield more help.
United Kingdom - Member -
Re: Valve Trim
07/07/2010 4:38 AM
Hi,
To quote 'Valvology' booklet: "Trim: The internal components of a valve exposed to the flowing fluid, ie. the Seat, Disc and Spindle."
Sometimes 'Trim' is used to refer to the 'Disc' or 'Valve Member'
Here is a picture of a simple Stop Valve to illustrate:
The Seat is not always machined as part of the Body, it can be a separate item.
I hope this is of some use.
Drew
Re: Valve Trim
07/08/2010 5:18 AM
thank you..
what about the inner lining of the valve body? Is that also called trim? if yes then, Is the inner lining is made of 13% cr for any carbon steel valve body?
Re: Valve Trim
07/08/2010 1:06 PM
Not sure what you mean by the 'inner lining'. If you mean the material surrounding the Spindle in my sketch, that's called a 'Bonnet' and is not part of the Trim and would not normally be made of stainless steel in a carbon steel valve (unless your standard product was stainless and making a carbon steel version would be an expensive one-off)
Could you enlarge on your comment please.
Drew
Re: Valve Trim
07/08/2010 10:30 PM
no no not bonnet.. i meant to say the body itself. after flowing through the valve body only, the fluid will be able to come in contact with disc, stem and other trim parts. so i was asking whether internal part of body can also be considered as a part of trim. hope u get me now..
Re: Valve Trim
07/09/2010 2:34 AM
No, the Body is not considered part of the trim.
It is not unusual to have stainless trim parts in a carbon steel valve, but it will be quite tricky to have a stainless inner surface in a carbon steel body (ref your comment #4)
I would endorse P.W.Slack's comment and have a look at Wikipedia.
Drew
Re: Valve Trim
07/09/2010 7:05 AM
Thinking about this further; it is fairly common to have a stainless steel (440C) or corrosion resisting steel (BS3S145) Seat brazed into a carbon steel Body. This could conceivably be specified as part of the valve trim. Perhaps this is what you had in mind in post #4
Drew
Register to Reply 8 comments
ad016 (4); lyn (1); PWSlack (1); vishnudev (2)
