Previous in Forum: Resulting Pressure From Thread Driven Hydrolic Piston   Next in Forum: Grade Of High Tensile Steel And Expected Salary For A Trainee In Oil
Turbines
07/06/2010 4:27 PM
Why the stages of steam turbine are more than gas turbine?
Re: turbines
07/07/2010 3:51 AM
1. Which cycle the Steam turbine runs? and which the Gas Turbine ?
2. The Steam Turbine is basically a/an (impulse/eraction/hybrid) turbine whereas Gas Turbine is a/an (impulse/reaction/hybrid) Turbine
Re: turbines
07/07/2010 8:30 AM
It does little good to simply type your homework question here.
If you tell us which ones you believe are correct, and why, we will discuss it with you.
Good Answers: 58
Re: Turbines
07/12/2010 9:51 AM
The statement is simply not true - there are many turbines with a two stage Curtis wheel or eve a single stage wheel, so they have the same or fewer stages than some gas turbines.
The answer your teacher is looking for has more to do with the beviour and properties of steam compared to the behaviour and properties of a b****y hot gas.
Anonymous Poster (1); Doorman (1); The Prof (1)
