I have a design idea and need to know some things about the function of a hydraulic piston that drives hot water under pressure of maximum of 15 bars capability, but will not need to run at that load.
The piston will be driven by a ball screw linear thread system that is run by a direct drive from a stepper motor shaft or of a 2 stage planetary gearbox on the stepper. Which would be better?
Requirements are-
Precise advancement of piston by a step motor controller
Smooth movement
0-15 bar range and anywhere in between
Things i know-
Thread pitch will affect how much torque i will need- steeper thread pitch=less torque and more speed.
Things i don't know-
What is the method of determining rotational power needed to drive piston at up to 15 bars without stressing stepper motor too much?
If it helps- the flow rate is 2 oz in 25 seconds for a base starting point (will vary) and the water temperature is 200+/- F.
Piston cylinder ID is 3" -approx- 4-6" travel of piston.
