Previous in Forum: Power Factor and Induction Motor   Next in Forum: Paralleling Two Transformers
Distribution Transformers
07/07/2010 5:56 AM
Why vektor goup Ynd5 and Dyn5 most of use for distribution transformer?
Re: i want to ask
07/07/2010 6:12 AM
since they are considered as "economically" feasible solution for this kind of transformer and have good technical consideration related to used material,harmonic protection,etc.
you can view other details in this forum
Re: Distribution Transformers
07/07/2010 2:12 PM
Hi,
when we use goup Ynd5 or Dyn5 for distribution transformer that means the phase shift of transformer is 150degree that has to be cancel out so that nearby transformer can operate parallel operation.
so that in cascade connection we select Ynd5 then Dyn5 then Ynd5 so on...
Vikas Dangi
07/08/2010 5:38 AM
Then this can be done with different shifts also!? (other than 150...)
07/09/2010 5:43 AM
what the reason vector group ynd5 and dyn5 often for distribution transformer ?
Good Answers: 170
07/09/2010 8:07 AM
Where is it so?
Anonymous Poster (1); electricalexpert65 (1); johnmanoe (1); LAA_Lucke (1); vikas_dangi (1)
You might be interested in: Power Transformers, Transformers, Telecom Transformers
