Previous in Forum: Project   Next in Forum: Possible Causes Of Oil Leakage Through Oil Seals
Piping Mill Allowance
07/08/2010 1:37 AM
Hi, I would like to ask about the piping mill allowance in B31.3, according to B31.3, the 12.5% mill allowance is only needed when it is a seamless pipe, but I see that some piping designer takes the mill allowance into account for welded pipes as well. It is more conservative if one take the 12.5% into account for welded pipe, but according to B31.3, is it really necessary in taking that into account for welded pipe? Thanks!
Re: Piping mill allowance
07/08/2010 2:21 AM
The thickness of skelp linearly rolled into pipe is tightly enough controlled that a 12.5% allowance is not needed. But then the seam must be welded, so a weld efficiency could come into play. I'm not sure, but I understand that ERW (electric resistance welding) can be considered 100% efficient.
Seamless pipe requires extrusion over an external mandrel, whose center could vary 12.5% from the center of the die from which the extruded material emerges. Hence the 12.5% deduction for seamless forms.
I don't know if this is a fully correct explanation. Moreover, it takes some visualization to figure out what is really going on.
A better explanation would be most welcome.
07/09/2010 2:20 AM
• Per ASME code material, and reference to the pipe material specification, there is a reference ASME standards telling yours to use a specified standard.
• For example, when our piping material is ASME SA 106, one of the reference material standard is ASME SA 530 "Specification for General Requirements for Specialized Carbon and Alloy Steel Pipe" which govern the mill tolerance.
• From ASME SA 530, we find that there are a lot of materials which uses the general specifications AS 530, like SA 106, SA 312, SA 335, ... etc.
• Per ASME SA 530, the permissible variation in wall thickness is indicated in Para. 8.1 which covers seamless and only welded without using filler metal.
• Per ASME SA 530, the attached Table X1.1 indicates the min. wall thickness based on a mill tolerance 12.5%. Where, tn (1-12.5%) = tm or tn (0.875) = tm
Note. For welded pipes used filler metals, the tolerance of plates shall be applied, taking into consideration the reduction in thickness due to forming.
Reply Good Answer (Score 5)
07/09/2010 8:50 AM
Thank you for the detailed answer (I rate it GOOD ANSWER). What do you recommend using for "the reduction in thickness due to forming" ?
Good Answers: 76
07/09/2010 8:56 AM
GA!
It should also be noted that many of today's tube/pipe consumers require tighter tolerances than the various standards require.
Having worked in the Welded Tube & Pipe Industry pretty much my whole life, with equal time split between working for an OEM designing Mills and working for tubing producers, half-ASTM Standard is the norm for about 95% of our customer base. And about 40 to 50 percent of those require tighter-than-half.
The majority of the tubing, not sure about pipe, that is supplied direct from the mill to the customer requires tolerances far tighter than current standards require. Generally those orders that are simply per-standard, are orders for Service Centers such as Ryerson and E.M. Jorgensen. Because, if you just wanted standard tubing or pipe, you wouldn't buy mill-direct unless you were looking at significant volumes.
JavaHead
Abdel Halim Galala (1); JavaHead (1); Mechanicalmark (1); Tornado (1)
You might be interested in: Piping Services, Piping Systems
