Previous in Forum: Engine Calibration Program?   Next in Forum: How Does Petrol Turbo Work?
15 comments
AWD vs. FWD for Traction in Snow
07/08/2010 11:30 AM
I am a senior citizen in upstate NY who on occasion might be out in a sudden snowfall of about 6 inches. My old FWD has served me pretty well in those conditions. Will I be better off with AWD when purchasing a new car? The biggest problem here is that there is generally a layer of old frozen snow/ice on side roads all winter. Will AWD help with traction? Thanks for input.
Re: awd vs fwd for senior citizen in syracuse, ny
07/08/2010 11:51 AM
Yes AWD will help you with traction, but often this makes people foolishly fearless in bad weather. An old off road warning about four wheel drive should be kept in mind. Four wheel drive means that one can drive deeper into the woods before requiring a tow.
07/08/2010 11:58 AM
I assume that FWD is 4 wheel drive. All wheel drive is just like 4 wheel drive that works all the time. The more driven wheels you have the better. The newer vehicles are designed for all wheel drive and get reasonable gas mileage, so, by all means go for AWD.
Yes, AWD will help with traction.
07/08/2010 12:48 PM
I assumed and I believe the automotive industry standard FWD means Front Wheel Drive. 4 Wheel Drive (4WD) maintains the slip required between right and left tires that is required when one makes a turn (longer travel length) but does not allow for slip between front and rear axles and often the front axle spins slightly faster than the rear axle. This is a preferred for off road use but will wear out tires faster with road use. All Wheel Drive (AWD) provides slippage between all four wheels and does not add any additional wear to the tires but not as much added traction as 4WD.
07/08/2010 1:32 PM
That is what I was thinking but couldn't articulate it. I knew 4WD has better traction but couldn't think of how to say why.
Drew
07/08/2010 2:58 PM
What is it "they" say? It is better to not respond and appear dumb than to respond incorrectly and remove all doubt.
Well, I've removed all doubt.
Thanks for the clarification.
Good Answers: 29
07/11/2010 1:59 PM
I like to say "A closed mouth gathers no foot," and "I rarely miss an opportunity to keep my mouth shut." Except here of course.
Si vis pacem, para bellum
Good Answers: 146
07/08/2010 12:42 PM
Okay, I have driven both 4wd and Awd, in icy and snow conditions. On the basis of that experience I would not recommend all wheel drive. Four wheel drive is better - the best in fact for the winter conditions IMO. In my experience, an allwd will spin out in slippery conditions where a 4wd would have no problem at all.
Incidentally, I have the same feeling about sudden stops at high speed with allwd - the car handles like it wants to do a 360 instead of a stop under those conditions - although I haven't actually done it, I beware.
incus opella
07/08/2010 12:56 PM
Please disregard my earlier comments. The advice of both artsmith and redfred comes from people who obviously drive in the snow regularily.
I live in the desert, what do I know about snow? Not much.
Listen to the guys who know.
Good luck and safe motoring.
Good Answers: 119
Re: AWD vs. FWD for Traction in Snow
07/08/2010 1:47 PM
I'm going to define these for my post:
AWD = All Wheel Drive (full time)
FWD = Front Wheel Drive
RWD = Rear Wheel Drive
ASR = All Season Radial
I've been driving in the wonderful "lake effect" region of WNY for over 30 years. Lived in Buffalo, now Rochester, with lots of travel to Syracuse, Finger Lakes, and the Southern Tier.
IMHO, AWD is clearly superior OFF road. ON the road, AWD is only marginally better than FWD and only if you use snow tires during Winter. Due to a larger selection of vehicles, typically better gas mileage, and lower cost, I currently prefer FWD vehicles (sub compacts) for my daily drivers.
In Winter, the tires alone make a huge difference. It is my experience that a FWD vehicle using good snow tires (without studs) will beat almost any AWD using all season radials. I travel rural roads to/from work daily. These get plowed last and I often drive through 4"-6" of fresh snow and "white-outs" with blowing drifts up to 12". Not many other FWD/ASR vehicles attempt these roads without needing a tow out of a ditch.
NOTE: I've seen several AWD vehicles (with over-confident drivers) slip off an icy road into a ditch. Only careful driving and/or studded snow tires will make any significant difference if you are really driving on ice.
Obviously speed control is important. I'm normally a very proactive driver (with chronic leadfootitus) but have learned to keep it under control during adverse weather conditions. The ONLY time I ever got "stuck" was driving up a snowy incline in an old RWD using all season radials. Once I started rotating to snow tires on that vehicle, it worked well enough (RWD was still twitchy) to get me through a few winters. Every Winter I still see many RWD pickups fish-tailing all over the road. That always makes me laugh (remembering when I went through a similar misery) and really appreciate my current FWD/snow-tire combo.
I don't understand why most people living in this region don't rotate to snow tires in Winter. On my vehicle, an extra set of inexpensive steel rims and good snow tires goes on in late October and off in late March. Once you experience the large difference between real snow tires and any all season radials, you will understand my point. I know, rotating snow tires may not be for everyone. Storage and rotation cost could be an issue. It works for me since I have a storage space and rotate the tires myself. IMHO the 20-30 minutes, twice a year, is well worth the effort.
Even if you decide to get an AWD vehicle, you will be amazed at how much BETTER it handles snow using real snow tires. Good luck!
Good Answers: 29
07/11/2010 2:15 PM
GA from me.
I too have driven the lake effect snow covered roads of that part of New York State. Highway 104 between Rochester and Ontario every workday for three years. Many times; while driving cautiously on fresh snow, I was passed by some aggressive, over confident driver in a four wheel drive vehicle. As mjb said, you would often pass them a mile or so down the road off in the ditch. Added a little humor to an otherwise tense situation.
Given that experience I have to agree with everything mjb said.
Good Answers: 146
07/11/2010 6:52 PM
Given the sweltering condition at the moment, it's a little odd to be talking about snow and ice!
It's been awhile since I drove a FWD (front wheel drive) but if I had to rate all types for traction on a crap icy road, it would be in this order: 4 wheel drive best, front wheel drive second best, all wheel drive third, and rear wheel drive last.
A front wheel drive with decent snow tires is perfectly okay, but there's no doubt 4wd is better - and I do assume snow tires in all cases - I wouldn't drive in winter without them.
I don't think they even sell RWD's up here any more (do they still make em?). My last one was a Caprice Classic with ABS, and honestly was pretty good on the road with snows on the front and studs on the back. Try getting her out of an icy parking spot, though... forget it!! Spin and wait for spring.
incus opella
08/02/2010 6:30 PM
"It's been awhile since I drove a FWD (front wheel drive) but if I had to rate all types for traction on a crap icy road, it would be in this order: 4 wheel drive best, front wheel drive second best, all wheel drive third, and rear wheel drive last." --------------------------------------------------------------------------------- Interesting theory - that FWD bests AWD in snow/ice. If you drive in an area with frequent ice/snow on the roads - you're best off with AWD. AWD is always engaged (at the ready) - so you don't have to consider whether or not the road conditions require 4WD (and you can't run in 4WD all the time because of engine/drive-train wear and MPG considerations). Any road in these areas may be 'mostly great' until you round a corner and hit just enough 'black-ice' to send you to the ER. So - you rely on AWD to make that instant call for you. I'm sure some will find something to argue about - hell, we still have a 'flat-earth society' too - but this question is a no-brainer for anyone who's had to drive in lots of inclement weather. I'd also argue that -->most<-- 4WD systems are not not advanced enough to be as effective as a good AWD system. Some are. If I needed to drive in ice/snow conditions frequently (and I do) - and I had 'bang for buck' considerations - I'd buy a Subaru Outback. In fact it would require $15-25k additional disposable income before I thought of anything else. My 2 (snow and ice covered) cents.
08/02/2010 6:37 PM
Oh... and you did say Upstate NY snow... most of my snow miles are on those roads. Some may not realize it but these roads are among the snowiest-iciest roads in the country (east of the Great Lakes / constant lake effect snow - but don't take my word for it - check the stats) ---------------------------------------- Great Winter Tires (not all season tires!) and careful driving are more important than any drive train though. Safe driving.
Good Answers: 146
08/02/2010 9:29 PM
I live in Newfoundland, in a rural area. I have had to drive in lots of inclement weather and neglected road conditions in winter. They are not "mostly great", unfortunately. If you think my opinion is on some inexperienced basis, well, you are wrong, Mr. Guest. I don't understand why people like you choose to be insulting instead of just stating your opinion.
"... you rely on AWD to make that instant call for you". Well this may be a point of preference. The front wheel drive requires skill to handle icy conditions - a skill the OP will have developed from past experience; the all wheel drive does not permit you to engage any such skill and if the car decides to spin, too bad. You have no control.
I'm talking about a Subaru Impreza AWD, I've been driving the last 5 years. That's a small car, the Outback is heavier and no doubt has better handling in winter conditions, as does any SUV or crossover vehicle, irrespective of the FWD/AWD or 4WD. It's a common strategy to load a few sacks of sand in the back of a small car, here, to add traction in the worst conditions. Weight. Like winter tires, an important point. Another reason why so many people just choose SUV's, most are 4WD though.
You say you would buy an Outback, and you say you drive in ice/snow conditions frequently, but you didn't say what you are actually driving. Is AWD "the thing you want" in your fantasy, or is it the thing you drive every day in the ice and snow?
BTW, I have been in an accident on black ice. It was "NO WHEEL DRIVE", no brakes, no nothing to do but wait for impact. I don't know that any system is proof against black ice.
incus opella
07/23/2010 12:33 AM
AWD is the best especially if it is a modern street car system that is electronically controlled. Various sensor read wheel speeds and the axis of travel then make inputs to keep you straight and safe! Your old FWD cannot compare to a modern AWD both in safety and capability!
Reply to Forum Thread 15 comments
Anonymous Poster (2); artsmith (3); Drew K (1); Engineering Superman (1); lyn (3); mjb1962853 (1); PMoon (2); redfred (2)
