How to design pulley, flywheel, bearing and shaft for Turbine Microhydro. Rpm for turbine is 1000 rpm and generator is 1500 rpm. The power is transmited from turbine to generator is 40 kW.
Well, if you mention that 40 Kw is transmitted to generator, and generator shaft is turning at 1500 rpm, so, you must have a torque of approx. 255 Nm (Power = torque x angular speed, use consistent units).
With this value, please inform what kind of transmission do you need. Do you need to locate the generator aligned with the turbine? Or it's an offset? Or it needs to have an angle? Please specify the location of the generator in respect to the turbine to allow a better choice of materials.
With the type of transmission, check if the generator shaft can be used to support the transmission element, or if you'll need a shaft with a pair of bearings to support a pulley and transmit only the torque to que generator.
You could use the bottom-end from an outboard motor (many are
available in 40 to 100Kw range)... and then put chain drive to the
generator
on the dry end with sprockets sized appropriately to turn 1000 rpm into
1500 rpm.
Naturally, this supposes that you will provide adequate support for all components.
