Previous in Forum: Max Process Temperature of Pressure Gauges   Next in Forum: Practical Significance of a Valve Positioner
8 comments
Wake Frequency Calculation
07/09/2010 9:33 AM
Wake frequency calculation is more stringent in case of gas service or liquid service?
Plz specify application criteria
Be happy :)
Re: WAKE FREQUENCY
07/09/2010 10:13 AM
The modern vortex-shedding flowmeter can be set-up electronically for particular gases or liquids, so there really isn't any need to worry. Simply follow the set-up instructions in the original equipment manufacturer's information that comes with the instrument.
Re: WAKE FREQUENCY
07/09/2010 1:00 PM
Sorry i framed wrong ques!!
What i wanted to ask is , in case of thermowells we do wake frequency calc. Either gases or liquids are tough to handle here , wat gives more vibrations??
Good Answers: 101
Re: WAKE FREQUENCY
07/09/2010 8:06 PM
It depends upon operating conditions of course, but generally speaking, liquids are much denser than gases and are incompressible, so they'll give more vibrations.
Re: WAKE FREQUENCY
07/22/2010 3:54 AM
it depends on fluid velocity, not fluid state , you can refer ASME PTC 19.3 standard for thermowell wake frequecy calculation.
Re: Wake Frequency Calculation
07/10/2010 12:26 AM
Wake Frequency is much dependent on Velocity of the Flowing fluid -Its not dependent on state of the fluid
Regards
Jose
07/10/2010 2:27 AM
So shall i assume , if velocity is same then liquid will have more impact comapared to gases.
Be happy :)
07/10/2010 3:38 AM
Whats Ur application
05/01/2012 4:06 AM
According to New ASME PTC 19.3 TW-2010.
The max frequency ratio limit for Liquid phase - 0.4
The max frequency ratio limit for Gas phase - 0.8
Register to Reply 8 comments
Anonymous Poster (2); DVader1000 (1); josej (1); KBL419 (1); msn (1); PWSlack (1); Ramesh143 (1)
