Previous in Forum: Galileo Finances Could Result in More Delays   Next in Forum: Solar Panels Lose Efficiency When Too Hot
Line Pipe Thickness
07/10/2010 9:19 AM
Please let me know why the price of a pipe increase inversely to the thickness, for eg. if we are purchasing API 5L X 65 pipe the price will increase with the reduction in thickness, i.e price of 8.7 mm thk pipe would be more than 11.9 and the same would be more than 14.3 mm pipe.
Re: Line Pipe Thickness
07/10/2010 11:25 AM
It's a conspiracy (or just a piracy) on the part of safety fanatics to get folks to buy heavier-walled pipe.
Or maybe an urban legend? (I'm not sure this is true to start with.)
Or just a wrong formula, such as $ = kdl/t?
07/10/2010 11:40 PM
maybe supply and demand and economies of scale
07/11/2010 8:52 AM
Because having thinner thickness needs more force for forming or extrusion
and also sometimes extra processing is required
also the percentage of scrap is higher
07/11/2010 10:37 AM
I would be curious to know your exact circumstances. Be it ferrous, non-ferrous, fiberglass, poly, etc I have never run into this situation. Thicker pipe always costs more in my neck of the woods.
07/11/2010 11:22 PM
I think is is simple logic:
The total cost of the pipe comprises of many factors like: (Here we are comparing the pipes with same OD or ID but varying thickness)
1. Material Cost: This reduces with reduced thickness. Probably, you are considering this factor only, while raising your thread. This factor is less dominant in total cost of the pipe.
2. Process Cost: The process cost per length remains same. Thus, process cost per Kg increases as the weight (means thickness) reduces.
3. Transport cost: This is complex calculation. Weight reduces with reduced thickness, but the volume for all pipes remain same. The transport cost is calculated by some complex formula, where both weight and volume is considered. Then volume consideration is predominant, the cost per weight increases.
Thus, effectively. the cost increases with reduced thickness.
Good Answers: 67
07/13/2010 12:59 AM
I beleive in opposite for same length of pipes. More of material will cost more, if other things are similar. You should not generalise your experience. It may be a specific and stray case for a perticular type of pipe(for ex- seamless etc.) or of specific material(for ex- SS, non-ferrous, plastic etc.).
If you are comparing the price per unit weight basis, then definetly thicker the pipe lower the cost. Please check.
Register to Reply 6 comments
bmac (1); gsuhas (1); Mohmed Iman (1); pritam (1); Sourdough (1); Tornado (1)
