Hi All,
We are manufacturing different Ratings of LV Alternators (5 kVA to 1010 kVA), we are struggling with one peculiar Problem of Generated Voltage Unbalance – This is 3 Phase STAR Connected Alternators.
We have done following -
1. The Phase Voltages of all 3 Phases are balanced.
2. The Line Voltages are unbalance by 4 Volts.
3. The Phase Angle of the Voltage Vectors measured as 0,119 & 240°.
4. The Total Harmonic Distortion Measured as Phase A - 1.5 %, Phase B - 1.3 % & Phase C -1.2 %.
5. We have Cut Opened the Armature Windings (Main Stator) to check the Basic Winding Specifications (No of Conductors, No of Turns etc) – All found OK.
We suspect following –
1. Can this Happen due to the Pitch Error of the Armature Stamping.
2. Can This Happen because of the Damper Winding Circuit of the Field ( Main Rotor) not Short Circuited Properly – e.g some blow Holes in the Brazed Joints of Damper Bar & Damper Lamination.
Please help..
