Previous in Forum: How Many Aerosol Cans Will Fit into the Bin?   Next in Forum: UK Libel Law Reform - Latest
Plating this Magnesium Metal Layer onto Carbon Steel
07/12/2010 8:22 AM
I have a small carbon steel tank that I want to plate the inside with magnesium metal. I have a source of magnesium. How should I go about accomplishing this?
Re: Plating this magnesium metal layer onto carbon steel
07/12/2010 9:29 AM
What is in the tank, its pressure and temperature?
Good Answers: 16
Re: Plating this Magnesium Metal Layer onto Carbon Steel
07/12/2010 11:45 PM
There are lots of ways to do it.
How good a job do you want and how long does it have to last?
If the inside of the tank is etched you could just throw in some magnesium powder, add some ball bearings of appropriate size, fill the tank with C O2 and seal the tank. Then rotate the tank. This hammers the soft metal into the etched surface.
You could try Sherardising.
http://en.wikipedia.org/wiki/Sherardising
You could even shrink fit a solid Mag liner or a foil liner.
The purpose size and life expectancy would be useful information.
By the way magnesium burns beautifully and it is great fun to watch some body try to put it out with water. Dangerous but interesting.
BAB
Make it so.
Good Answers: 243
04/11/2011 10:10 AM
Magnesium is too active a metal to elctroplate out of an aqueous solution. Mechanical bonding as others have suggested looks to be the most likely method. What thickness of coating? what other properties you looking for?
Milo
Register to Reply 3 comments
BlueAussieBoy (1); Milo (1); PWSlack (1)
