Previous in Forum: Difference Between Total and Net Filtration Area   Next in Forum: CMM Service Works - Air Pad Gap
VVCP High Speed Reciprocating Compressors
07/13/2010 2:07 AM
We have in our facility a GE Gemini FS 704 high speed natural gas reciprocating compressor.
Its Construction is as follows:
1st Stage compression Cylinder A and B, Discharge pressure 14.5 bar
2nd Stage compression Cylinder A and B, Discharge pressure 46.0 bar
The 1st stage Cylinders have VVCP (Variable Volume Clearance Pocket).
Fixed capacity control is achieved by manual adjustment of Variable Volume
Clearance Pockets (VVCP) on each cylinder. This allows the basic compressor
capacity to be changed efficiently, to suit varying gas compositions, turbine demand
and site conditions.
I need more information on the VVCPs. What is the general construction of a VVCP?
How is it adjusted?
Thanks..
Re: VVCP High speed reciprocating compressors
07/13/2010 2:32 AM
Good Answers: 27
07/13/2010 5:14 AM
A good look at the drawings for your machine will give you the construction of your particular clearance pocket.
In general a VVCP consists of a cylinder (pocket) with a piston in it attached to the outboard cylinder cover. By moving this piston one increases or decreases the clearance volume of the cylinder. (This only affects the cylinder cover side of a double acting compressor such as yours).
The movement of the piston in the variable volume pocket can be achieved manually or can be automated and hydraulically or pneumatically actuated based on volume or pressure control. Do you have any specific questions on these systems?
I have no special talent. I am only passionately curious. Albert E
Register to Reply 2 comments
