Previous in Forum: Motor starting   Next in Forum: electric moter
11 comments
need high dc voltage low constant current diagram
07/14/2010 3:19 PM
device I need must have high voltage output and current limited at 0.2 mA all the time. Load of the circuit is variable. Need this for galvanize process which needs to be as shorter as can be. I have two electrodes in the distilled water and current trough electrodes needs to be limited at 0.2mA because I need nano size particles which rips from anode into water and nano size I will get with such low current. Constant current at that value will provide constant nano size of particles in the water. I tried to get what I need with two different current limitation diodes (j500 and 1n5283) and 50V dc adapter, diodes keep the current constant but the problem is when distilled water begins to fill with electrode particles and resistance of the distilled water start to drop, voltage in the circuit also start to drop.After few hours of process voltage drops under 10V and ripping of anode last for days to get a lot of electrode particles in the water(that is what I need).Higher voltage in the circuit means faster ripping of anode and faster process. Is it possible to make circuit with much higher initial voltage and current limited to 0.2mA and is it possible when load becomes lower somehow voltage prevent to drop?
Good Answers: 82
Re: need high dc voltage low constant current diagram
07/14/2010 4:41 PM
You want a classic current source. There are hundreds of ways to make these, and if you ask the question on a forum like usenet's sci.electronics.design, you'll begin getting them coming out of the woodwork. Or you could do a Google groups search and read scores of current-source threads from yesteryear. But I'll save you the trouble and post four quick possibilities.
The first circuit presents 1.2 volts from an IC zener reference, across a sense resistor, and routes the resulting current to your load. Use any small PNP transistor that can handle 60 volts. The second one uses the Vbe of a PNP transistor to create a 0.65 volt reference for your sense resistor. It saves parts but is less accurate.
The third one is more elegant, using a 90-volt opamp to buffer your current-output node, and then adding 1.2 volts to that voltage to power a resistor, creating 200uA into your load. This one could be easily be made precise to 0.1% or so, and as a bonus, it gives you a low-impedance voltage-monitoring output. A real Source-Measure circuit, if you like.
But my favorite circuit is the fourth one, because it's self-powered and therefore has only two terminals and is the ultimate in simplicity. It uses a depletion-mode MOSFET that can be used from 1 to 500 volts, and it relies on the fact that its Vgs needed to bias to a given drain current is very little affected by the drain voltage Vds. You don't know the exact Vgs vs Id for a given part, hence the variable-resistor current-adjustment pot. "My favorite" LND150N3 comes in an easy-to-solder TO-92 package and costs 69 cents at Mouser.
Thanks, Win
07/14/2010 6:41 PM
thanks for the answer
I am not good in electronics but i can make device by the diagram. If I make device by these first tree diagrams will I have drop of voltage like I had with those current limitation diodes? With those current limitation diodes I measured voltage before I drop electrodes into water and voltage between them was 56V after I put them in water voltage immediately was cut off on 22V and dropping after that when water starts to filling with ions from electrodes. Same thing happened when I tried this with 33V adapter from one old printer,those diodes cut my initial voltage at the same level of 22V. The 1n5283 diode can handle up to 100V but I did not try to make power source of 100V because I would probably got voltage cut on those 22V as well(which is not enough), I need a lot higher voltage in the start of process so the process last for couple of hours not days like it is now. I prefer fourth diagram but as I said before my load in circuit is not constant so what will happen when resistance of the distilled water drop? If I make device by the fourth diagram will the current stay constant as resistance start to drop? I am asking this because i can not stay near the process all the time and adjusting level of current by the pot.
Good Answers: 82
07/14/2010 7:42 PM
We have a term for that issue with current sources, and it's called the compliance range. This is the operating-voltage range over which the current-source circuit correctly delivers the desired value. The compliance range for all four of these circuits is very good, since they only need a small minimum voltage for their own operation. I've listed the ranges below:
Ckt Vmin Vmax
1. 1.4V Vbreakdown
2. 0.8V Vbreakdown
3. 5v 85V
4. 3V 500V
As you can see, all the minimum requirements are well below 20 to 30V or whatever you might have struggled with.
Also, the LN150 would allow you to use a high-voltage supply, above 80 volts, which could be dangerous!
Please be careful. You should have a hinged safety enclosure with a breaker microswitch, which disconnects the high voltage unless the lid is closed. Another rule is, one hand behind your back. This is so you can avoid any dangerous through-the-chest shock currents.
Thanks, Win
07/15/2010 6:58 AM
thanks again for the info
I am aware of danger from high voltages and because i need higher voltage that I can get(higher voltage=faster process) using of lnd150 will be the best in this case. As i said before i am not good in electronics so can you tell me what will happen with the current in fourth circuit when resistance of load start to drop? Will I need to adjust it by the pot every time resistance is change or current will remain at the same level once I regulate it on the start of the process?
Good Answers: 82
07/15/2010 3:13 PM
The two-terminal current-source circuit will increase or decrease its own voltage drop to maintain the current you set with the pot. That means as your load resistance changes, and its voltage drop changes, the current-source will take up the difference to maintain the correct current. The whole idea is that you should not have to re-adjust the pot.
Naturally, being as enamored of this scheme as I am, with my "favorite" LND150 part, and all, I've got bench data to show how well it works, or fails to work. Here's a plot that will appear in the third edition of The Art of Electronics, showing the accuracy of an LND150 with a self-biasing resistor to make a current source.
We show three different current values measured over a 1.5 volt to 500-volt operating range. As you can see, if we run the LND150 at 500uA the current increases by 1% as we go above 100 volts, but if we're running it lower at 100uA a 1% increase doesn't happen until we get above 300 volts. If we're running at 10uA we have to push all the way to its 500-volt rating to see a 1% change.
You haven't said how much accuracy you need, but this should help you to see if it'll meet your needs. As usual, there are ways to increase the accuracy by adding more parts.
Thanks, Win
07/15/2010 8:16 PM
Well, maximum level of current depends on a volume of anode, in my case maximum current should not bi higher than 0.4mA,it can be lower ten or more times than 0.4 mA but higher no.
So let say that I build power source that can give 480V (lnd150 can handle max 500V), and my current must always be under 0.4mA, it does not matter if current is for instance 0.010mA because with that current I will also get nano size of particles. I measured resistance of distilled water and before process it is around 1.5Mohms.How to calculate what resistance to put between pins of MOSFET(gate and source if I am right)?? I used your fourth circuit in multisim 10.0 and to get 0.15mA in the start of the process i must used resistor of 1.5 Mohm. So initial Voltage (according to multisim) drop from 480 to 215 Volts(which is high enough) and after I lower the resistance of the load to 150 Kohms Voltage drop to 50V and current rise to 0.28mA.. By the time when resistance of the water drops to some 50 Kohms I usually have enough particles in the water so I change the value of load resistance again, this time from 150 to 50 Kohms and mutisim showed me that voltage in the circuit will be 15Volts and current around 0.3 mA(which is less than 0.4 and OK). Do you have any formula to calculate what resistance i must use between pins and do you think that multisim was accurate in this case?
Good Answers: 82
07/15/2010 8:28 PM
You cannot use Multisim or any other spice to analyze this circuit, unless you have an accurate model of the mosfet, which I'm pretty sure you don't. There are a number of reasons, but one is because spice models fail to work properly in the sub-threshold region. Anyway, you really don't need spice to understand the current source; I have shown you the performance curves. If you have a high-impedance load that can't draw 0.2mA, then the mosfet will sit turned on like a switch with no more than 1 to 2 volts across it, as the curves show, presenting nearly the full voltage of your power source to the load. When your load does finally start drawing current, when it reaches 0.2mA the mosfet will then start using up whatever voltage it needs in order to maintain 0.2mA as the maximum current.
Thanks, Win
07/16/2010 3:53 AM
OK
Thanks very much for your answers, you helped me to understand how circuit works!
Best regards
Good Answers: 82
07/17/2010 6:33 AM
You're very welcome. Your work sounds interesting. There's more I would like to have said, but it could clog up the forum. I'd like to know more about your distilled-water application. Drop me an email, my address is my name, no spaces, at yahoo.com I can tell you a few more details, add a simple high-voltage high-impedance measuring scheme, and if you like send you a drawing of a relevant instrument we made in our lab.
Thanks, Win
07/19/2010 3:17 PM
I wrote you an e-mail on WinfieldHill@yahoo.com few days ago but did not got respond yet. Wrong e-mail?
Good Answers: 82
07/19/2010 3:38 PM
Ooooops, you just posted my email address! Spam city!
Thanks, Win
