Previous in Forum: need high dc voltage low constant current diagram   Next in Forum: tell me abt electric genretor.....with diagram
electric moter
07/14/2010 3:37 PM
sir i want a AC moter of 500 to 750 rpm. plz tell me sutable moter....plz
Re: electric moter
07/14/2010 4:52 PM
If your network is 50 Hz, a 12-pole motor will be 500 synchronous rpm, and an 8-pole motor will be 750 rpm. If they are induction motors, they will run slightly slower, owing to slip.
Re: electric moter
07/15/2010 2:57 AM
Contact motor distributors locally, and give them some idea of the power range required and the application as well as the speed.
  • A 12VDC instrument motor doing 500-750rpm and pulling a few tens of mA would cost about £35GBP, whereas a 50kW motor for 415VAC doing 500-750rpm might be several £thousand.
Technical Fields - Technical Writing - New Member Engineering Fields - Energy Engineering - New Member Fans of Old Computers - UNIVAC - New Member Hobbies - Automotive Performance - New Member Popular Science - Genetics - New Member Safety - ESD - New Member
Re: electric moter
07/15/2010 8:40 AM
Motor selection requires HP, RPM, Voltage etc.
So your are silent on other two.
So AC motor with 750RPM is available.
Synchronous motors available with 500RPM and less
Re: electric moter
08/06/2010 9:56 AM
Mr.Vishu 91,
Your query is just like a child's which asks for a choclate ( Sorry for the
comment).
If you are serious to get a technically correct reply you are to give the following details.
(1) What is the duty of the motor- Continous or intermittant or stand by.
(2) The voltage available at your site.Frequency ( India 50 Hz)
(3) The local enviornment- Moist, Humid, Hot, Rainy etc so that you can
choose the type of enclosure- TEFC, TEDP,
(4) What is the area available- at lower speeds - motor dia may be more.
(5) Who is the vendor - will he give after-sales service.
(6) Natue of the load- Starting with loads- like Conveyor belts-Hoist
applications.
(7) Get a B2B directory and search for motor manufacturers, dealers,talk to
them- than wasting our time ( spoon feeding will expose your
idleness and reluctance to use your brain and time).
Manroop.Chennai.
Register to Reply 4 comments
kabeerta (1); manroop (1); PWSlack (1); Tornado (1)
You might be interested in: AC Motor Drives, DC to AC Converter Chips, AC Motors
