Previous in Forum: NCT   Next in Forum: Boosting the Power in a Solar Panel Charging Battery
Droop CT
07/15/2010 6:37 AM
Why use droop ct in genretors and what is the help of droop ct to synchronization of genset?
Technical Fields - Technical Writing - New Member Engineering Fields - Energy Engineering - New Member Fans of Old Computers - UNIVAC - New Member Hobbies - Automotive Performance - New Member Popular Science - Genetics - New Member Safety - ESD - New Member
Re: droop ct
07/15/2010 8:45 AM
AVR of alternator requires a droop CT.
In alternators of generators the voltage are drooping by increasing of load to the generators.
The AVR is working to increase or decrease the voltage to the normal voltage set to it
Normally the CT is nly done in one phase of winding
Good Answers: 244
Re: droop ct
07/15/2010 7:33 PM
Droop CT, also called QDCT (Quadrature Droop Current Transformer), is used for the control of sharing of reactive power (VAR) between parallel connected generators. When generators run in parallel, it shares the real power (KW) as well as the reactive power (VAR). The sharing of real power is controlled by the prime mover governor, while the sharing of reactive power is controlled by the AVR (Automatic Voltage Regulator). In addition to voltage input, the AVR requires the current input for controlling the reactive power. So, the secondary of the quadrature Droop CT is connected to the AVR for providing the power factor dependent signal to the AVR.
See these documents for more detail of droop CT:
http://www.mtspowerproducts.com/download/mcp/data_sheet/voltage_regulators/SS440%20Instructions.pdf
http://www.dieselgeneratorsmiami.com/recursos_tecnicos/NEWAGE-SX440-AUTOMATIC-VOLTAGE-REGULATOR.PDF
http://www.datakom.com.tr/files/data_sheets/AVR8_DATA.pdf
The droop CT is not required during the synchronization but it is required for the parallel operation of the generator(s) after the synchronization is completed.
- MS
Re: Droop CT
07/16/2010 2:08 PM
Quadrature droop circuit
converts the current input into voltage, which is phase mixed with the sensing voltage. The
result is a net increase in the output from the sensing network as the power factor lags, causing the reduction in excitation
needed for reactive load sharing of parallelled generators.
A trimmer allows control over the amount of droop signal.
The above is from MTS SS440 AVR.
Droop CTs compliments in the efforts of achieving voltage stabilization and paralleling operation in generators
DICKSON
There is peace in silence and achievement in plans.
Dickson (1); kabeerta (1); msamad (1)
