Previous in Forum: Whitworth Tools   Next in Forum: 1998 Chevy S-10 with a 4l460e Transmission Shifting Issue
Car Problems - Help? (2000 Chevy Cavalier)
07/15/2010 1:36 PM
I apoligize in advanced for my lack of knowledge. I am a mom of two, both with health issues and alot of doctor appt, in ohio. I own a 2000 chevy cavalier 2.2 liter 4 door automatic. I had a timing chain replaced 2 years ago, throttle sensor done about year ago, and fuel pump done 4 months ago all by a mecanic. My car had seemed to be idling high for about a month then on my way home from hospital a month ago it broke down just stopped running and would not start back up. I finally was able to get my cousin to look at it and he said the car had compression so it was not timing belt he suggested i replace the coil pack, spark plugs and wire which a friend done but it still wont start. i do not have money to take it to shop was hoping someome has a suggestion. Remember i dont have alot of knowledge about cars.
Re: PLEASE HELP
07/15/2010 1:56 PM
Hello, stephaniea4321. Sorry to hear your troubles.
A quick check reveals yours to be thread #64 regarding this generation of Cavalier... since March of 2009. You do not seem to be alone.
This link will reveal the previous discussions regarding the "My Cavalier will not start/run/stop blowing horn/go into gear" troubles we have already discussed on CR4. You may find something there (there are 500 posts to go through).
I do not wish to seem like I am blowing you off, but just about every Cavalier seems to be a candidate for the recycle yard.
United States - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: PLEASE HELP
07/15/2010 2:01 PM
The car is 10+ years old. You have had to replace a couple things on it already... it seems as though it is on the downhill track toward replacing. I predict soon enough that the cost to fix all of these maladies will outweigh the cost of just getting another vehicle. I would suggest finding another car.
But if you decide not to do car searching, Doormans post (#1) will probably be most useful.
Good Answers: 60
Re: PLEASE HELP
07/15/2010 2:22 PM
Ask your friend to try the crankshaft sensor. possibly one from a scrap yard for cheapness.
But as others have said it is unfortunate that you have a cavalier, You may also try to get the codes read from the engine management you will need a special tool for this
Re: PLEASE HELP
07/15/2010 3:06 PM
Sorry to hear about your predicament, hope I'm not insulting you, but with mechanics fees running about $85 per hour plus parts, this may be worth looking into, you may even be able to use your car as a trade of some sort, http://www.ehow.com/how_5011948_donated-car.html
Good Answers: 58
Re: Car Problems - Help? (2000 Chevy Cavalier)
07/15/2010 5:11 PM
Check the distributor pickup coil.
http://www.google.com/images?q=chevrolet+distributor+pickup+coil+image&rls=com.microsoft:en-us:IE-SearchBox&oe=&um=1&ie=UTF-8&source=univ&ei=jng_TJ3AOujtnQfjsrCVBQ&sa=X&oi=image_result_group&ct=title&resnum=1&ved=0CCEQsAQwAA
When this small and somewhat inexpensive (if you replace it yourself) device fails you are not going anywhere.
Hope this helps - Good Luck!
Good Answers: 60
07/15/2010 5:23 PM
ah ha no crankshaft sensor then,i wasnt sure .
Good Answers: 123
07/15/2010 11:29 PM
Sorry to hear of your problems. Ask your cousin to test for spark while trying to start the car. just remove one of the spark plug wires and put another spark plug in the wire and make sure the hex shaped part of the plug is against the metal part of the engine.( You can use one of your car's plugs if no spares)
If you have bright blueish white spark, you probably have a fuel problem.
If you had spark, replace the spark plug wire, (and plug if removed) and pour about a thimble full of gasoline into the air inlet of the engine. Not the air filter, the metal throttle body that the gas pedal is connected to. Have a garden hose that is charged standing next to the car and then try to start again.
These two tests will get you in the correct direction for 0 money. Let us know results, and we will go forward. Good luck.
Bob
Register to Reply 7 comments
bob c (1); Doorman (1); Jaxy (1); KJK/USA (1); kramarat (1); peterg7lyq (2)
You might be interested in: Timing Screws, English Pitch Timing Belts
