this transmission will not shift in to low or over drive when you pull out it pulls out in second gear i was told to check the components on the valve body and we did and they checked out fine we checked out the 1-2 accumalator and its fine we checked the servo with air pressure and its fine there is nothing stuck in the valve body, we unplugged the wiring harness from the transmission and had it off the ground and the transmission still changed just like it did when it was plugged up could this be an electrical problem. the transmission came out of a 19198 blazer that was wrecked the transmission worked good in the blazer but wont work right in the chevy s-10, its a 4l460e transmission. i would appreciate any input on this if any one knows anything about this type of transmission.
