Previous in Forum: Electrical System Design of a Building   Next in Forum: High Voltage, 30kv and Low Voltage Cable 400 Volts
VVVF Controlled Motor Tripping
07/16/2010 12:11 AM
Dear all
One of our cement mill separator motor 430 v 415 kw Delta connected VVVF controlled (ABB ACS 800) motor Tripping the reason showing unbalance.
ACS 800 having two nos of inverter module, we tested with one by one (separately) module then the motor running without any problem
If it with two inverter the problem is showing again anybody having any experience same these situations? Please be advice to us
With Regards
jcg
Re: VVVF Controlled Motor Tripping
07/17/2010 12:59 AM
Based on your information it is ACS800 multidrive with two inverter module.
Does it show number of inverter causing current unbalance?
Check DC link votage going to Inverter Module a difference of few volt can also cause the problem.
Regards
Bharat
07/19/2010 7:26 AM
DC link voltage is same
I will give some more details of the drive
ACS800-04-0870-3+E205+V991
Inverter
Input U 513...587 VDC
I 889 ADC
Output U 3 ˜ 0...415 V
I 741 A
f 0...300 Hz
Line converter
Input U 3 ˜ 380...415 V
I 630 A
f 48...63 Hz
Output U 3 537.....587 Vdc
I 764 ADC
With regards
jcg
07/17/2010 9:30 AM
Maybe you can check ACS800 setting.
Engineering Fields - Petroleum Engineering - Rig Electrician United States - Member - the Oil Patch Engineering Fields - Power Engineering - Drives & Gen's Engineering Fields - Instrumentation Engineering - Drive Control Popular Science - Cosmology -
07/17/2010 9:37 AM
if running with an encoder check it, try running open loop (without the encoder) and see if you get a trip
Why do they make manhole covers round? so they won't fall in [before asking "Who is John Galt?"]
07/18/2010 10:31 PM
Your both the drive units are individualy running ok, means the control going to both the Drives through APBU (DDCS Branching unit) may be the problem OR Optical cable missing the signal.
Thanks,
sukhvinder singh
JK-PAPER LTD, RAYAGADA
07/19/2010 3:01 AM
We replaced a working APBU from other units but the problem is showing again (tripping happening after some time of the motor running only )
With regards
JCG
Register to Reply 6 comments
Anonymous Poster (3); jcg154 (2); kwcharlie (1)
