Previous in Forum: Basic Information - Mechanical Eng. Products   Next in Forum: Hydraulic Thread / Tube Dash Size
Location of Vibration Probe
07/16/2010 1:45 AM
Pl give me details of location of vibration probe and RTD's in LP/HP compressor in Process gas compressor
Re: Location of vibration probe
07/16/2010 5:08 AM
What make?
What does the manufacturer's instruction booklet say?
07/16/2010 5:15 AM
i am not expert in the RTD, but i can say that the best place to check the vibration is on its bearings
Good Answers: 27
Re: Location of Vibration Probe
07/16/2010 8:30 AM
As close to the bearings as practicable for the radial probes and looking at either the shaft end or the thrust disk for the axial probe. Shaft surface must be round and polished.
I have no special talent. I am only passionately curious. Albert E
Hobbies - Musician - New Member Engineering Fields - Mechanical Engineering - New Member
07/17/2010 12:09 PM
you should read the manual / drawings. the radial vib probe must be at radial bearings; but the mounting position, whether it is 0-90 degree or 45 degree left & right or else , you should check it on the compressor or the drawings.
jignesh142 (1); Kaisan (1); PWSlack (1); sir anrava (1)
