Previous in Forum: Using Carpet Fibres to Reinforce Soil   Next in Forum: Bricks
Bearing Capacity of Soil
07/16/2010 4:02 AM
What are the factors affecting the Load Bearing Capacities of soil?
Re: Bearing Capacity of Soil
07/16/2010 4:23 AM
realy sos but i cant help u there
07/16/2010 7:32 AM
its structure
Good Answers: 58
07/16/2010 9:30 AM
Greetings zanzibah,
The factors vary based on composition, density, moisture content, ect. The following is an excerpt from a Geotechnical Engineering Report that may give you some insight. I am only posting two pages of the report as the report contains 33 pages total. If you would like to see the complete report, e-mail me with your e-mail address and I will e-mail it back to you.
Soil Conditions
Conditions encountered at each boring location are indicated on the individual boring logs.
Stratification boundaries on the boring logs represent the approximate location of changes
in soil types; in-situ, the transition between soil types may be gradual. Subsurface
conditions at the borings can be generally described as follows:
Asphalt that ranged from 5 to 7 inches in thickness was encountered at the surface of 6 of
the 10 borings. In the remaining borings, topsoil fill that ranged from 5 to 10 inches in
thickness was encountered. These surface materials were typically underlain by fill and
possible fill materials consisting of crushed concrete, fine to medium sand, silty sand, lean
clay and sandy lean clay. The fill and possible fill typically extended to depths ranging from
about 3 to 8 feet below the ground surface. These materials were underlain by native soil
deposits of stiff to hard lean clay, sandy lean clay, and sandy silt that extended to the
termination of the borings.
The cohesive soils in the upper 30 to 45 feet of the borings exhibit relatively stiff strength
properties. Standard penetration "N" values in the native clays typically ranged from
about 7 to 15 blows-per-foot in this zone, and increased to 20+ blows-per-foot below
that. Pocket penetrometer values for the clay soils in the upper 45 feet of the borings
ranged from about 3000 to 9000 pounds per square foot (psf). Very stiff to hard
cohesive soils commonly referred to as "hardpan" were encountered in the borings at
depths ranging from about 43.5 to 58 feet, but was typically encountered at about 44 to
48 feet.
Please refer to the attached boring logs for the laboratory data and a detailed description of
the subsurface conditions encountered at the individual boring locations.
Groundwater Conditions
The borings were observed while drilling and after completion of drilling for the presence
and level of groundwater. At these times, groundwater was observed in 7 of the 10
borings at depths ranging from about 8.5 to 50 feet below the ground surface. The water
level observations provide an approximate indication of the groundwater conditions
existing on the site at the time the borings were drilled. Some of the relatively shallow
groundwater observations are likely the result of trapped or "perched" water which is often
encountered in more pervious near surface strata such as fill and sand seams. A longer
period of time to monitor the groundwater levels in cased holes or piezometers, sealed
from the influence of surface water, would be required for a better evaluation of the
groundwater conditions on this site.
Fluctuations of the groundwater levels will likely occur due to seasonal variations in the
amount of rainfall, runoff and other factors not evident at the time of this subsurface
exploration. Therefore, groundwater levels during construction or at other times may be
different than the levels indicated on the boring logs. The possibility of groundwater level
fluctuations should be considered when developing the design and construction plans
for the project.
ENGINEERING RECOMMENDATIONS
Geotechnical Considerations
The soil boring data and laboratory test data were evaluated to develop
recommendations for site preparation, as well as, design and construction of
foundations, floor slabs and pavement subgrades. Our draft report contained
recommendations for supporting the proposed building on spread footing foundations
and a structural mat. We understand that these options have been ruled out for support of the proposed structure. Please see our draft report for these recommendations.
Based on conversations with the project structural engineer, we understand that the
proposed building will be supported on drilled shaft (caisson) foundations. For drilled
shafts that bear in the hard clay (hardpan) layer encountered in the borings at depths
ranging from 43.5 to 58 feet, we recommend an allowable bearing capacity of 12,000 psf
(6 tsf). It is our experience that performing the pressuremeter test in the hardpan soils
encountered in the borings would justify a much higher allowable bearing capacity,
which would improve the economy of caisson design.
Some building elements such as entry-ways and structures associated with the power
generation station will be constructed using shallow spread footings. Based on the "N"
values and hand penetrometer data, we would recommend that an allowable bearing
capacity of 4000 psf be used to design shallow spread footings bearing on native soils.
Some miscellaneous fill materials were encountered in the upper 3 to 8 feet of several
borings, we recommend that shallow footing excavations extend through these fill
materials. Shallow foundations could bear at the deeper elevation or the excavations
could be backfilled with 3-inch stone to the original design bearing level.
Our recommendations for design and construction of foundation, the on-grade floor
slabs and pavement subgrades are provided in the following sections.
05/02/2011 9:28 PM
Greetings KJK/USA plz email me all 33 pages(Bearing capisty of soil) at <email removed>
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses. You can share this information via the CR4 internal messaging system.
07/22/2010 7:52 PM
factors affecting bearing capacity include grain size distribution; structure, orientation and angularity of grains; minerology and stength of mineral particles; organic content and type of organics; particle packing/orientation; particle surface interaction (friction); and hydrogen or chemical bonding. BTW these also affect angle of fiction and cohesions coefficients. Typically load bearing capacities are set by geotechnical engineers based on the designers needs within the calculated limits of the soil, thus if the soil bearing capacity calculates to be 6500 psf, and the designer only needs3500, the geotech will usually report a limit of about 4000 or so.
Asad_PAK (1); hazza (1); jignesh142 (1); KJK/USA (1); RCE (1)
