Previous in Forum: Bearing Capacity of Soil   Next in Forum: Engine Test Bed Construction
Bricks
07/17/2010 2:59 AM
Dear All,
Please tell me the calculations for caluculation the no of bricks in One cum of Brick Masonary wall.
regarda
ranganath
Re: Bricks
07/17/2010 9:26 AM
What size is the brick? How thick is the mortar joint?
Re: Bricks
07/17/2010 11:52 PM
~1.1/(volume of brick + mortar). The reason for 1.1 rather than 1 is to account for bricks that must be cut to fit at each end of the wall.
Good Answers: 58
Re: Bricks
07/19/2010 4:48 AM
For good quality face bricks with small tolerances of L/B/W of 5/3/3 mm then 52 bricks/m2.
For rough stock bricks or fancy stuff with 12 mm grout then somewhere between 45 and 54 bricks/m2.
This assumes a brick of standard L/B/W of 222/106/73 mm.
You do not state where in the World you are, but these dimensions are for imperial bricks, so if you are in one of the old British colonies they may well suit.
Used to make these things for a living in a previous life........
lyn (1); The Prof (1); Tornado (1)
You might be interested in: Bricks, Masonry Services, Refractory Shapes
