Previous in Forum: Best Way to Store GPS Coordinates? (What Data Type?)   Next in Forum: Destructive Interference - Common Mode Rejection
Out of Phase Voltages
07/18/2010 8:39 AM
geometric sum of three equal sinusoidal voltages that are out of phase..how can it be solved out?
Re: out of phase voltages
07/18/2010 9:58 AM
By knowing the phase angle of the three voltages, converting the voltages to the real and imaginary components and adding. Now finish your homework.
07/18/2010 7:08 PM
Yeah! What he said!
Bla - de - bla - de - BLA!!! "That's Me!!!"
Good Answers: 119
Re: Out of Phase Voltages
07/18/2010 8:16 PM
You didn't specify phase angles.
Crayons and a ruler can be used to find resulting phasor R=A+B+C graphically...
07/21/2010 4:14 AM
Hint: the resultant vector sum is the voltage between neutral and earth....
08/20/2010 1:07 AM
The previous post showed you how to do it. With a vector diagram. You should thank them.
If all three are not only equal in amplitude, but 120 degrees apart, they will sum to zero.
Anonymous Poster (1); mjb1962853 (1); PWSlack (1); redfred (1); Walts_Worker (1)
