Previous in Forum: Welded Base Plate   Next in Forum: Bench Grinder For Stainless Steel
Welding for Aircraft
07/19/2010 5:22 AM
What type of welding is suitable for aircraft? (gas welding, arc,spot welding)? Otherwise is it a molded one?
Re: Welding for Aircraft
07/19/2010 10:37 AM
Welding on airplanes is best left to the experts. I'm not one, although I've done some welding in the past. I'm almost sure that you are not a welder nor a pilot.
It's sort of like asking someone how much something costs. If you have to ask, you can't afford it. You can't afford to work on an airplane if you are not a certified A&P mechanic with welding tickets.
Leave it to the experts!
07/19/2010 3:56 PM
Now days glue and double-sided tape are quite common. No, this is not a joke!
Can you please provide more information? Are you talking about structural welding or joining?
07/19/2010 4:19 PM
Please, not glue. Adhesive.
Beechcraft Starship, Boeing 787 Dreamliner and all of Scaled Composite's products make extensive use of non-metallic composites.
07/19/2010 8:33 PM
That all depends on what your definition of "aircraft" is (passenger or model). Mind you, adhesive inspires more confidence in the structural integrity of a joint than glue.
Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Marine Engineering - New Member Engineering Fields - Aerospace Engineering - Aeromarine Vehicle Engineer
07/19/2010 11:40 PM
The Lockheed P-3 Orion has a lot of spotwelding both Class A and B used in such areas as the Nacelle Longerons which are stainless steel and the Vertical Stabilizer Leading Edge Fillet which is aluminum.
On the B-1B the Vertical and Horizontal Stabilizers had sinewave beams made of Titanium 6Al-4V which were stitch welded using SMAW in a weld box that was filled with argon gas.
Welding on aircraft is very high tech and requires a lot of process development, qualification, and certification.
The above is based on experience over the last 25 years.
07/27/2010 4:30 AM
thank you for your response...
Register to Reply 6 comments
dhinesht (1); Gannet (1); jack of all trades (2); lyn (2)
