Previous in Forum: Joining Corundum and Steel   Next in Forum: Drain Trap Sizing
Hydraulic Cylinder Calculation
07/19/2010 10:27 AM
how to calculate hydraulic cylinder force in kgf,piston speed in m/s,flow rate liters/min,and pressure is in kg/cmsq
hoping for best
Re: hydraulic cylinder calculation
07/19/2010 11:03 AM
These parameters are interrelated - you've got to fix a couple of them (and specify the load characteristics (mass, friction, angle of motion relative to the horizontal) and pump characteristics) to be able to calculate the others.
What is your specific problem? What do you already know?
07/20/2010 11:14 AM
dear sir, i have hydraulic cylinder working pr is 160 kg/sm2,bore dia will be 63 mm,piston rod dia will be 36mm,so i needed flow rate in m3/s,speed in m/s,cylinder pr in kgf i want general calulation of hydraulic cylider that to in unit what i mentioned and if further more information you needed please mail me hoping for the best thank you have a nice day
07/20/2010 7:04 PM
I don't recognize the units "kg/sm2".
Please log on when replying.
07/21/2010 7:59 PM
Register to Reply 4 comments
Anonymous Poster (1); JohnDG (2); woodygb (1)
