Previous in Forum: Hydraulic Cylinder Calculation   Next in Forum: BI and BC Impellers
Drain Trap Sizing
07/19/2010 12:07 PM
We have black start Diesel engine started by air compressor. I need to select/size a drain trap suitable to install in the compressor vessel and what parameters to be checked to ensure the trap will function correctly.
Aprreciate your inputs
Re: Drain Trap Sizing
07/19/2010 6:55 PM
Please! the flow rate is? the vapor liquid is
klearzen
07/20/2010 12:03 AM
flow rate through the trap is compressed air while the liquid to be removed from system is water condensate resulting from compressing the air. so my question is what have to be checked before buying a drain trap and what is the type of trap suitable for compressed air application.
07/20/2010 12:12 AM
flow=compressed air
liquid=water condensate
07/20/2010 12:57 AM
A 1/2" (13mm) bucket trap ought to work just fine. A smaller trap might suffice, but it won't cost much less.
Register to Reply 4 comments
klearzen (1); power engine (2); Tornado (1)
