Previous in Forum: ECU plugs   Next in Forum: Fixture Design
EPDM Flexible Hoses Requirement
02/28/2007 3:44 AM
can any one interested in supplying the EPDM flexible Hoses
Size - 200NB
Flanged end
3m long
Quantity 48 No.
Re: EPDM Flexible Hoses Requirement
03/01/2007 12:45 AM
Please contact with Ms.Helen Hu,email: mecomfginc@yahoo.com.cn
william.bei
04/06/2007 6:46 AM
Please specify the working pressure, working media, Temperature which will enable us to quote for EPDM Flexible Hoses.Also please specify the Flange dimensions & the M.O.C of flange.Send your enquiry to email : bijeshenterprises@rediffmail.com.
03/01/2007 9:28 AM
Yes,
I would like to supply them to you ,
I need more especifications,
Size - 200NB (This is not clear) What size, diameter, especifications on the flange connections.
I need a target price in order to supply this to you,
Flanged end
3m long
Quantity 48 No.
I need a drawing or something approved to star manufacturing.
Please reply to me:
Pedro Gutierrez
Pegusa Inc.
www.pegusa.4t.com
9 Knickerbocker Road
Tenafly, NJ 07670-2411
+1-201-227-1560
+1-201-655-0042
Fax: +1-206-339-8775
+1-206-203-0923
e-mail: pegusallc@hotmail.com
pegusamail@yahoo.com
pegusaincorporated@gmail.com
03/01/2007 11:09 AM
What's the thickness of the hosese? What's the size if the flange? You need 3m x 48 pcs, right?
03/06/2007 3:55 AM
EPDM hoses should no problem to offer you. I can get you any length and diameter you require.
You said you require 3 meters in length, but what about your diameter requirement? Do you need 100mm, 125mm, 150mm or bigger?
You said you would like to have one end flanged. Would you like a blank flange with no holes or do you require flange with holes? Where are the holes? Do they follow a bolt circle? How many holes? What is the diameter of the holes?
What about the flange material? Do you need HDPE, steel, stainless steel flange materials?
I cannot help you until you answer these questions. I cannot be held responsible for following you request and furnishing you with improper products.
I will be out traveling in a few days and won't be back for 3 or 4 weeks. Please respond at the earliest opportunity.
Ed Atkinson
Anonymous Poster (3); Ed Atkinson (1); user-deleted-1114 (1)
