Previous in Forum: Power Transformer   Next in Forum: US Trimmer Adaptor in India
12 comments
India - Member - New Member
Cable Selection for Feeder
07/20/2010 2:50 AM
Pl. suggest cable size calculation for underground cable feeder from power utility to plant in desert area.
Plant load of 25 MVA, feeder route length 5 KM, System volatge 33 KV? and suggested future margins in selected cable size
When was last time you did something for first time.
Good Answers: 170
Re: Cable Selection for Feeder
07/20/2010 8:05 AM
Please referv to Cable Manufacturers' Catalogues. Apply all de-ration factors. Also, give due consideration to Voltage Drops. Also, ensure the short time withstand rating of the cable.
07/20/2010 8:31 AM
Dose there exist standard for permissible voltage drop in feeder.
07/20/2010 9:37 AM
Yes! Please refer to IS 1255.
07/22/2010 12:23 AM
Normally it is taken as 5-10%.
BB Raina
07/20/2010 12:39 PM
Happy
We don't like to do the work for the engineer. Do the following
1. Convert the load to amps from the info 25 MVA and 33 kv
2. Select a MFG for your cable
3. Select a cable based on the amperage requirements
4. Calcullate the VD using this cable to determine if it meets your requirements. If not
5. Select a bigger cable and repeat #4
I would like to see you work so please post it for us to see
07/22/2010 10:17 AM
How do you do
About item#2, please clarify "MFG" summery.
Kindest regard
AMIR
CR4 Admin – E-mail Address Removed
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses.
07/24/2010 12:18 AM
Hi Amir,
Are you in Iraq?
If so, please write me a private message on this forum, I can help
thanks
dont say it, write it
07/21/2010 7:17 AM
2X 630 mm2 Al cable runs per phase based on certain assumptions on derating factors short circuit time duration. This should suffice. You may like to check and come back and share with us your findings.
BB Raina
Good Answers: 11
07/21/2010 8:01 PM
wareagle has given you an excellent comment please also consider the ambient temperature and the cable's max.operating temperature. There must be high temperature than normal places.
07/22/2010 11:08 AM
MFG = manufacturer of the cable
07/24/2010 7:46 AM
Hi
1- Load current
2- all derating factors llike depth , temp , grouping ---
3- this will give you an approx cable rating for cable size
4- check voltage drop across cable
5-check short ckt capability for cable
make 2 sets of cable if permitted
rgds
Correct me if i am wrong i am learner
07/30/2010 9:30 AM
25MVA? 33KV? This sound like a major job. But to ask here listening to random answers with question like what is "MFG" is really mind boggling
Register to Reply 12 comments
Anonymous Poster (2); BB Raina (2); electricalexpert65 (1); Hameedullah Ekhlas (1); Happy singh (1); ikhanuk (1); Le_Noble (1); leng48 (1); wareagle (2)
