Previous in Forum: Sulfuric Acid from Battery Room   Next in Forum: project
Air:Fuel Ratio - Coal Fired FBC Boilder
07/23/2010 8:51 AM
Hi. What is the air - fuel ratio of coal fired fbc boiler? And how much percentage of excess air required for complete combustion?:-):-)
Always be a leader
Pathfinder Tags: Mechanical eng
Re: About Firing System - Air:Fuel Ratio
07/23/2010 9:50 AM
Let me have the composition of your coal
RK
Re: Air:Fuel Ratio - Coal Fired FBC Boilder
07/23/2010 11:44 AM
I don have any details of coal other than gross calorific value
Always be a leader
07/23/2010 6:43 PM
what kind of readings are you currently getting at minimum safe firing rate? the minimum safe firing will depend on the fuel the fire box /burners ash handling bag separators preheater/ economizers temps do your instruments currently measure @ 5-15 % percent excess o2 how does the fire behave do you get complete combustion?
klearzen
07/23/2010 9:46 PM
Hi. I know the furnace draft of 5mm of water column. Ash handling equipment is mechanical dust collector and preheater is available for preheating of forced draft air.
Always be a leader
07/24/2010 12:54 PM
To much excess air creates a slight cooling effect, but insufficient o2 is the culprit when trying to capture all the heat available in the fuel.
your goal is .....complete combustion with a minimum of excess air.
klearzen
brkmech (1); klearzen (2); SIVASUBRAMANIAM (2)
