Previous in Forum: HCL or Na2HSO4   Next in Forum: The pH of Some Aqueous Solutions
14 comments
Drinking Water PH
07/25/2010 3:35 AM
Our water maker is a vapuour recompression type with sea water as feed and heated to 90 Deg and flashing to a chamber with low pressure and then cooling the vapours. This water is collected in a big tank which is having a capacity for 5 days. The water maker will be in line for 1-2 days for filling the tank and put on circulation for flushing the system with same sea water and switched off.Recently the drinking water outlet from the unit is having a PH of 4-4.5 only and this after going to the tank and after two days starts increasing and the tank sample shows PH 5-5.5 . As per the normal standards the drinking water should have PH of 6.5-7.5. My concerns are below.
1.why the PH is coming to 4-4.5 from the water maker outlet as we are not adding any chemical in the unit.
2.This water maker out let sample if kept in a beaker and checked after two days automatically increasing to 5-6 PH.
3.Presently the drinking tank water PH is not increasing more than 5.5. Is it safe to drink or how to correct the PH
Pls give your ideas/suggestions to overcome this problem as we are working in a vessel in sea.
Good Answers: 141
Re: Drinking water PH
07/25/2010 5:26 AM
It seems you are drinking distilled water. No minerals in it. You should at least add a little salt to not dehydrate. Further your water could be wine, beer, which are normally also acidic (PH<7).In general, a water with a pH < 7 is considered acidic and with a pH > 7 is considered basic. The normal range for pH in surfacewater systems is 6.5 to 8.5 and for groundwater systems 6 to 8.5. Alkalinity is a measure of the capacity of the water to resists a change in pH that would tend to make the water more acidic. The measurement of alkalinity and pH is needed to determine the corrosivity of the water. The pH of pure water (H20) is 7 at 25oC, but when exposed to the carbon dioxide in the atmosphere this equilibrium results in a pH of approximately 5.2. Because of the association of pH with atmospheric gases and temperature, it is strongly recommended that the water be tested as soon as possible. The pH of the water is not a measure of the strength of the acidic or basic solution and alone does not provide a full picture of the characteristics or limitations with the water making process. -----
In general, water with a low pH (< 6.5) could be acidic, soft, and corrosive. It could leach metal ions such as: iron, manganese, copper, lead, and zinc from the aquifer, plumbing fixtures, and piping. Therefore, a water with a low pH could contain elevated levels of toxic metals, cause premature damage to metal piping, (how does your distillation equipment look?) and have associated aesthetic problems such as a metallic or sour taste. The primary way to treat the problem of low pH water is with the use of a neutralizer. The neutralizer feeds a solution into the water to prevent the water from reacting with the house plumbing or contributing to electrolytic corrosion ; a typical neutralizing chemical is soda ash. Neutralizing with soda ash increases also the sodium content of the water.
Plenty of room here
Good Answers: 61
07/25/2010 10:01 AM
"The pH of the water is not a measure of the strength of the acidic or basic solution..."
That's exactly what it IS!
07/26/2010 1:17 AM
Actually I think dvmdsc had it correct when he said ...
The pH of the water is a measure of the H+ Concentration (Hydrogen ion, proton, or hydronium ion H3O+) in the water. It is a measure of the Acidity of the water, but it is not a measure of the strength of the acidic solution. http://en.wikipedia.org/wiki/PH
The strength of an acid (or acidic solutioin) is measured by the ability of the solution to donate a Hydrogen ion. This is measured by the acid dissociation constant (pKa) http://en.wikipedia.org/wiki/Acid_dissociation_constant
Lower the pKa the stronger the acid, higher the pKa weaker the acid.
Lower the pH is more acidic, higher the pH less acidic
There's an important difference, between the strength of an acidic solution and it's pH.
07/26/2010 2:29 AM
<...It is a measure of the Acidity of the water, but it is not a measure of the strength of the acidic solution....>
Are these two not one and the same thing?
07/26/2010 2:49 AM
Not quite.
pH is simply a measure of the concentration of H+ ions in the solution. Regardless of what acid has supplied them.
A solution that has very low pH only means that it has a high concentration of H+ ions. This will be an effective acid (by pure overwhelming numbers). An example is a plague of insects can do a great amount of damage.
pKa is a measure ofthe strength of the acid (how strongly it wants to give the H+ ions up). An elephant can also do alot of damage.
A weak solution with a strong acid doesn't have to have a low pH to be just as effective as a strong solution of a weak acid.
Hope this helps.
Good Answers: 32
07/26/2010 12:45 PM
"A weak solution with a strong acid doesn't have to have a low pH to be just as effective as a strong solution of a weak acid."
Since the wording is not precise, I'll stop short of saying you are wrong, but I believe you have a common misconception that strong acids are more "effective". It is a bit complex, but let me make a statement that is true, and see if you agree.
"For any given acidic pH, the solution that contains the weaker acid will be more effective"
To define "effective", let's say that effectiveness is the ability to supply the most ions to a given reaction.
It takes a higher concentration of a weak acid to produce the same pH as a stronger acid, so it will have more ions available for reaction.
This seems to be the opposite of your statement.
07/26/2010 3:15 AM
NO.
07/27/2010 5:23 AM
Why?
Good Answers: 32
07/26/2010 12:22 PM
The problem is the use of imprecise terminology like "strength". As others have pointed out, in chemistry the use of strong or weak when referring to an acid or base has a specific meaning; a description of how easily the compound dissociates in water.
In English, "strong" can mean several different things, such as concentration or how effective a solution is at performing a task (dissolving, reacting etc.)
pH alone does not not give an indication of concentration. A given low pH may be due to a low concentration of a strong acid or a much higher concentration of a weak acid.
Good Answers: 146
07/25/2010 6:59 AM
Is the boiler in your system, or the holding tank made of metal?
Corrosive elements in sea water could cause metal ions to leach from the tank and lower the pH. If the tank liner had been breached or metal become corroded, that could explain why pH of the output dropped compared with previous performance.
There are elements in seawater that can be vapourized. Sulfur for example can be vapourized as SO2 or SO3 gas, and lower the pH of the water condensate. This would explain why pH raises somewhat when the water is left standing: some gas is evolved but sulfur still remains as sulfuric acid, keeping the pH low.
http://library.thinkquest.org/C006669/data/Chem/reactions/water.html
If sulfur compounds are making it into the vapour condensate, the sulfuric acid content will speed the corrosion of a metal holding tank, further lowering pH with metal ions.
If your water maker is designed for seawater, there is probably (or should be) a filter on the vapour end that is to remove elements such as sulfur. The filter may have become clogged or corroded, allowing SO2 or SO3 to pass. Check the watermaker design for a filter that needs to be cleaned or replaced.
incus opella
Good Answers: 109
Re: Drinking Water PH
07/25/2010 11:44 PM
GA to DVDMSC and Artsmith.
The pH of pure distilled water is 7. As the storage of the water exposes it to air the CO2 from the air dissolves into it to form carbonic acid, the pH of your freshly distilled water will move down to about 5. If other impurities exist in the air the pH can drop further and perhaps to the 4-4.5 range. Acid rain is often measured at pH of 4 or lower, for example. I am not sure what material the tank is made but you should check for NSF/ANSI 61 compatibility. The changes of pH may indicate dissolving other materials into the pure water causing the pH to rise after going low for awhile. I can only guess to what could be dissolving into the water. Some lead may leach into the water but other metals are also possible. If this is for potable water purposes you may want to constantly make a fresh supply and minimize storage. HPC bacteria in the reservoir is another common problem especially if organic material is leaching in the water.
07/26/2010 12:56 AM
Check for electrolysis. Is your chamber grounded? You can simply add a soda to bring the alkalinity up.
07/26/2010 2:00 AM
I agree with the comments posted so far.
It does sound like the ultrapure water (with no buffering capacity) produced by the unit is being influenced by an unknown, resulting in the pH dropping.
The unit itself shouldn't be corroding from the water (as it "should" be designed to operate in the conditions). If you have downstream piping it may be corroding, however the pH change in the water as a result will be up (not down).
If you are worried about dissolved metals, go ahead and test for it, but I would consider this unlikely to be a problem. And not in high enough concentrations to cause health issues.
The theory put forward about the sulfur dissolving and carrying over (into the distillate) in the form of SO2/SO3 does make sense. SO3 + H2O → H2SO4(g) this reaction is typically extremely slow, so very minor amounts are likely to form, but it is an extrmely strong acid in an unbuffered environment, and therefore could explain your observations (low pH direct from the unit).
If the CO2 is being dossilved to form weak Carbonic Acid (below is equilibrium data from Nalco Water Treatment Handbook), then it could be stabilising at 5-5.5 pH as you observed.
My recomendations for what it's worth is to re-mineralise the water to add come buffering capacity (stabilise the water pH at 7 - 7.5 pH). We use Calcite (Calcium Carbonate chips) to do this. Suggest getting hold of some and throwing it into the tank (won't hurt). The calcite will slowly dissolve, and add Calcium and Carbonate ions into the water. The carbonate will act to hold the pH at constant levels.
07/26/2010 2:37 AM
<...Presently the drinking tank water PH is not increasing more than 5.5. Is it safe to drink ...>
Comparison measurements of the pH of popular brands of cola (brand names withheld) would indicate yes, as these are of lower pH than this owing to the levels of phosphoric acid they contain, and kids drink gallons of it. The pH of freshly-squeezed orange or lemon juice would also be of interest in this regard.
It seems as though the re-hardening vessel, which should be at the back end of the processing train, is out of mineral. Inside this vessel should be a finely-divided calcium carbonate material (brand name withheld), the job of which is to raise the pH of the evaporator's outlet water and to give it some conductivity, which distilled water simply doesn't have. If the calcium ion concentration is below, oh, say 60ppm, then the water is unpleasant to drink on the grounds of palatability, and may even cause corrosion problems with downstream pipework and fittings on the way to the taps. Re-harden the water, by replenishing the re-hardening vessel's contents with fresh mineral and putting the equipment back on-line, and report back.
The fault seems to be one of not following maintenance procedures rather than anything else, at this time.
ajwinemaker (3); Anonymous Poster (2); artsmith (1); dvmdsc (1); energyconversion (1); kevinm (1); PWSlack (3); Tad (2)
