Previous in Forum: The pH of Some Aqueous Solutions   Next in Forum: Question
Water Desalinization
07/26/2010 8:10 AM
I have got a little deep well in my garden, but sometimes during the high tide period the salt water penetrates into it. What's the solution in order to desalinize the content of the well or whether after pumping out something can be done?
Good Answers: 101
Re: Water Desalinization
07/26/2010 8:52 AM
Since seawater is denser than freshwater, you could try installing some sort of waterproof barrier around your well extending maybe three or four meters below the high tide level. This should keep the seawater out of the shallower part of the well.
07/27/2010 5:21 AM
Oh, one might try media filtration below 5μm, carbon filtration to take out any taste, followed by a small reverse osmosis unit, then re-harden with finely-divided calcium carbonate and chlorinate.
Or one might try media filtration below 5μm, carbon filtration to take out any taste, followed by blending with the town mains supply to achieve a low-enough TDS and a zap with some UV prior to drinking it.
Or one might use the water without any treatment for the dozens of things that one does with water that don't require desalination (water the garden, flush toilets, take showers and baths, etc.) and rely on the mains supply for those that do.
The possibilities are manifold. Local circumstances will direct what to do, and they cannot be seen from here.
