Previous in Forum: Need Help Selecting Auto Battery Charger/Tender   Next in Forum: How to Evaluate Human Memory
Submercible Pump Selection for Irrigation System
07/27/2010 3:25 AM
I have bore in my farm which have a width-6" & depth-600feet.
So please help me for pump specification or pump size with all specification.
Re: Submercible pump selection for irrigation system
07/27/2010 6:23 AM
The things that are needed are:
  • The water quality - TDS, TSS, pH, etc.
  • The lift needed
  • The intended flowrate
  • The pipe routing
  • The pipe diameter
  • The daily volume requirements
  • The available power supplies
  • The weight of the pump
  • The weight of the pump discharge piping that is to be suspending the pump in the well
  • The method of connection together of the individual pipe pieces that are suspending the pump in the well, which may be a function of the weights above
  • The method of connection of the pump discharge piping to the pump
  • The method of inserting and removing the pump and its piping into the well
With this lot determined, one is then in a position to approach pump suppliers and see what might be available to select from.
Good Answers: 97
Re: Submercible Pump Selection for Irrigation System
07/30/2010 11:39 PM
Has a draw-down test been done?
CRTL-Z
