Previous in Forum: ADC Chip Ad73360   Next in Forum: Voice Recognition Chip - HM2007
Why Use -48 VDC Sources?
07/29/2010 12:40 AM
I want to know in technical words.why we use only Standard (-48 v)DC in telecommunication
Good Answers: 27
Re: Why Use -48 VDC Sources?
07/31/2010 10:07 AM
The only telecommunication equipment that are standardized to use the -48V DC are the telephone equipment. Providing sufficient and safe power for continues signaling and tone generations. An industry standards for equipment manufacturers.
vsar
07/31/2010 7:38 PM
I am not sure what you mean exactly...but.
I worked in telecommunications and a pulsed 50 v dc was standard for line operable...the buzzing you hear when you pick up the phone.
Probably just a matter of a good voltage with enough current to do the business of making a phone call......i.e. 2 volts would be not good and also 300 volts would be not good.
It is just safe"ish" and recognisable to the system down not the best quality cable.
I am a deeply religious nonbeliever - this is a somewhat new kind of religion. Albert Einstein
08/01/2010 3:11 PM
Just to add to your reply....
The most obvious reason for the 48 / 50 volt option is its a nice multiple of lead acid batteries i.e. 4 x 12 volt batteries.
The telephone network is designed to be fail safe and is expected to work when mains power is not available.
Register to Reply 3 comments
Electroman (1); portugalphilip (1); vsar (1)
