Previous in Forum: Human Vibration   Next in Forum: Back Board for Back to Back Handball Courts
10 comments
Rubberised Butterfly Valves
07/30/2010 3:42 AM
I am struglling to find the best rubber to be used on a butterfly valve with a medium of sea salty water, the current EPDM becomes hard after sometime and cracks,
Whats the best rubber that i can use.
Re: Rubberised Butterfly Valves
07/30/2010 4:35 AM
FFKMs
Good Answers: 29
07/30/2010 8:33 AM
07/30/2010 2:56 PM
FFKM refers to Perfluoro Elastomers.
I might have said Type 1 or Type 2 FKM.
If the guest who posted #1 had bothered to define for us the TLA (in this case a FLA) he may have gotten a GA vote.
TLA = Three Letter Abbreviation FLA = Four Letter Abbreviation GA = Good Answer
Good Answers: 74
07/30/2010 10:40 PM
Done. GA. ROLMAOASA, NLA, Nine Letter Abbreviation.
I hope I can still remember what they stand for, if someone asks.
The Twain Has Met
08/01/2010 8:42 PM
Apologies. I assumed the OP might know what was being referred to without considering that others might also be following the post and not know what it meant.
I shall make things clearer next time.
07/30/2010 1:30 PM
Good Answers: 49
07/30/2010 10:34 PM
Have you tried Teflon coated blades and seals?
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
08/01/2010 8:00 AM
The best thing is to contact your valve supplier for this problem. If not known, contact M/s Intervalve, Pune or M/s Audco , Chennai.
08/02/2010 2:43 AM
I have worked some years ago for a butterfly valves manufacturer, and I can confirm EPDM is he best choice for sea water application. I you encounter problems, it is more likely because of the poor quality of the EPDM than because it is EPDM.
08/02/2010 12:50 PM
The best rubber for this application is silicone wich can last much longer and perform better under sea conditions than the best EPDM in the market. Try to use Phenyl Silicone.
Register to Reply 10 comments
Anonymous Poster (3); Doorman (1); energygod (1); kramarat (1); ky (1); martinev@inter-sil.com (1); piriet (1); RDGRNR (1)
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
