Basically I have a system which I need to know the times and dates when the system is active. There is a 12V DC circuit connected to a switch and a light. When the system is active, the switch closes and illuminates the light. I want to tap directly into this circuit with a device that is able to recognize the DC voltage and record the time and date the system turns on. Computer interface via a mainstream connection is required. Connecting via serial and terminal emulator would be a good place to start.
I have searched fruitlessly for a solution to the problem. If you have any ideas or know of any products that match this description please let me know.
